Y Pipe???
Old May 4, 2012 | 09:56 AM
  #46
Splatts's Avatar
Splatts
Clay- do the set of IC boots come with the plenum boots too? If I click the early 99 will I get the plenum boots that reduce to the right size?
Old May 4, 2012 | 10:19 AM
  #47
1dieselman's Avatar
1dieselman
Looks to me like they do, just go down the list checking what you need. So if you are getting polished piping you aren't going to paint them are you? Maybe a translucent paint would look cool.
Old May 4, 2012 | 10:27 AM
  #48
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Yep, when you select it that is what we send.
Old May 4, 2012 | 10:36 AM
  #49
Splatts's Avatar
Splatts
Thats what I thought just had to double check. Thanks!! Be ordering them here in a minute!!
Old May 4, 2012 | 10:39 AM
  #50
Splatts's Avatar
Splatts
Are ther issues with painting polished alluminum? Not much of a painter. I just get the old rattle and go to town. Lol. I was wanting to do a dark red high temp paint or something.
Old May 4, 2012 | 10:45 AM
  #51
1dieselman's Avatar
1dieselman
May have to scuff it up and use a etching primer first. Check this out https://www.ford-trucks.com/forums/1...-my-7-3-a.html
Old May 4, 2012 | 11:55 AM
  #52
Splatts's Avatar
Splatts
Those pipes and IC look sweet! Thanks for the painting advise. I will definately be trying that primer.
Old May 4, 2012 | 04:12 PM
  #53
fordpride's Avatar
fordpride
Use a green 3M scotch pad to scuff them, prime, sand with 320 grit, wipe clean and paint
Old May 4, 2012 | 04:21 PM
  #54
Splatts's Avatar
Splatts
That how to get the professional look! Exactly what I am after thanks!!!
Old May 4, 2012 | 06:06 PM
  #55
Splatts's Avatar
Splatts
Anyone use the riff raff hpx? Does it still fit after the intercooler setup. It looks like the spyder gets in the way??? I haven't notices it is any of the writups.
Old May 4, 2012 | 06:10 PM
  #56
strokin'_tatsch's Avatar
strokin'_tatsch
FYI. there is a banks y and turbo outlet pipe for sale on PSA for $150. Just saw it. Title perfect start to OBS intercooler.
Old May 18, 2012 | 12:19 PM
  #57
Splatts's Avatar
Splatts
How is a good way to plug the 2 hose fittings on the y pipe? Can they be removed or should I cut them off flush and fill them with something.
Oh BTW Bahamas is amazing!!!! Just got back yesterday!!!!
Old May 18, 2012 | 12:39 PM
  #58
1dieselman's Avatar
1dieselman
Really you what someone to give you info after telling us how great the Bahamas was LOL.
Anyways I just pulled the hose fittings and threaded the holes for set screw style plugs.
Old May 18, 2012 | 12:50 PM
  #59
Splatts's Avatar
Splatts
Those fittings, just put some pliers on them and rip them out?? I think that is what I will do. Pull the fittings and have my welder buddy fill the holes.
Couldn't help but mention the Bahamas. Lol. Now it's back to the grind and working on the rig
Old May 18, 2012 | 01:45 PM
  #60
1dieselman's Avatar
1dieselman
Yep just pull them out.
