What am I missing here?
Old May 1, 2012 | 09:25 PM
elyrain's Avatar
elyrain
I've lost some power recently and I'm totally stumped now.
I thought it may be the ficm but SG2 shows 47-48 volts KOEO, and running/driving. I replaced both batteries last weekend just in case. Recent replacement of oil and oil/fuel filters. Cleaned my air filter 3 months ago. Just pulled the egr and it looked good. VGT duty cycle looks good also. EOT ECT are within 13 degrees of each other.
A few months ago I replaced the ICP/stand pipes and stc fitting from a non start condition. Fixed the problem perfectly.
I was getting a #8 injector low code a week ago and on another day I got a #7 code also. The codes have not come back though. I know it could be the injectors but they all seems to run fine after I get to normal operating temp.
What else could it be and what else could I check with my SG2?
Thanks.
Old May 1, 2012 | 09:31 PM
dlibson's Avatar
dlibson
When did you check the FICM voltage? Keep in mind voltage being good doesn't always equal good ficm.
Why do you seem to be wanting to overlook the cylinder contribution codes?
Old May 1, 2012 | 10:13 PM
elyrain's Avatar
elyrain
Why? Because I don't feel like spending 500$ to replace two injectors if that isn't the problem. Diesel injectors stick all the time when cold but run fine when warm. I forgot to mention that I'm getting a little degas puking. I drove about 170 miles today and it was just enough puking to make a 1/4" ring under the cap. May just be a bad cap but I don't know yet.
Old May 1, 2012 | 10:16 PM
dlibson's Avatar
dlibson
Well, the codes for the injectors give you two places to go. FICM, or the injectors...
Old May 1, 2012 | 10:38 PM
Roasted7's Avatar
Roasted7
That puking doesn't sound good. How full do you keep you degas bottle?
Is your boost normal? If it's off just a couple psi you'll feel less power. Check for leaks.
When you say your VGT duty cycle is normal, what does it read at idle? WOT?
Couldn't hurt to check the fuel pressure also.
Old May 1, 2012 | 10:51 PM
elyrain's Avatar
elyrain
Vgt is 85 at idle the goes down as the boost goes up, I wasn't watching it much past 50 because of the speed I was going.
I swear that it sounds like my turbo isn't whistling as loud as it used to also. It used to be annoying, now I have to try and listen for it. I'm beginning to think these problems may be compounding. Turbo getting worn, injector starting to go, and something with the degas.
Roasted7's Avatar
Roasted7
Also check EBP sensor and make sure the tube isn't clogged.
Old May 1, 2012 | 10:55 PM
Roasted7's Avatar
Roasted7
85 seems high to me. Mine is usually about 65 at idle but can vary.
Old May 2, 2012 | 01:47 AM
bismic's Avatar
bismic
Couldn't leaking head gaskets cause cylinder contribution codes?
Is your air flter an aftermarket filter? I assume so because you mentioned cleaning it. I ask because of the turbo issues and the poor condition of the impellors that you found last year before replacing your turbo with a used unit.
Old May 2, 2012 | 09:27 PM
elyrain's Avatar
elyrain
Just checked today and I'm only getting 22lbs of boost max. EBP is clean, map tube is clean and looks like new, no cracks.
Baro reading is 29.5 with KOEO
map is 14.4 and ebp is 14.4 also
VGT is 85 at idle and near 22 at max boost.
looked at the filter, still clean, impeller blades look fine also, but I didn't look at the hot side.
Mr. Finch
Nov 4, 2021 11:41 AM
Lubbockguy1979
Dec 13, 2016 01:09 PM
8lug
Aug 22, 2012 09:11 PM
Teds
Feb 15, 2012 07:42 PM
Bronco86
Jul 3, 2004 07:30 PM
