injectors
Old Jan 6, 2004 | 10:44 AM
Bronco86's Avatar
Bronco86
injectors
how can i check my injectors to see if they are working properly and/or not clogged? i have ran the KOEO and KOER tests witha reader and everthing checks out no codes. but my truck boggs out when i give it too much gas....the only thing i can think of is injectors!!!!! ............please help
Old Jan 6, 2004 | 12:35 PM
Blurry94's Avatar
Blurry94
What parts have you replaced recently that would lead you to believe the injectors are bad? Have you replaced the O2 sensor...maybe a tune-up?
Old Jan 6, 2004 | 12:44 PM
Bronco86's Avatar
Bronco86
i have replaced fuel pumps and filter, air filter, spark pugs and wires, map sensor, and adjusted timming to ~12. i then ran numerous KOEO and KOER tests......and i think the injectors are the only thing left.....if not let me know any suggestions
Old Jan 6, 2004 | 09:57 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you tested the tps? It's possible it could have some dead areas. Check it first with a volt meter or an ohm meter to see if it is bad before going and buying a new one.
Old Jan 7, 2004 | 10:17 AM
Bronco86's Avatar
Bronco86
bad areas? i tested it and it reads ok closed and Wide open
Old Jan 7, 2004 | 11:10 AM
EPNCSU2006's Avatar
EPNCSU2006
If you check it with an analog volt meter, you can see if it jumps around by slowly opening the throttle. There could be a bad winding in the tps and cause the voltage change to jump. There should be a smooth transition between the low voltage and the high voltage. Does the truck act up when you floor it, or just normal cruising?
Old Jan 7, 2004 | 11:16 AM
Bronco86's Avatar
Bronco86
only when i floor it
Old Jan 7, 2004 | 01:02 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you checked how much play there is in the timing chain?
Old Jan 7, 2004 | 01:04 PM
Bronco86's Avatar
Bronco86
no not yet
Old Jan 13, 2004 | 07:39 AM
mramelbass's Avatar
mramelbass
I just had my 87 Ranger's 2.9v6 serviced at a local repair shop. They had a machine called a "MotorVac" that they hooked up to my fuel rail. This machine then injects a detergent/gas mix that cleans out carbon in the engine. It cleans carbon from everywhere your gas goes. It cost $100.00 and took three hours. I found out from my local Napa dealer who had sold this "MotorVac" system to the shop. Go to www.motorvac.com to read more.
Old Jul 3, 2004 | 07:30 PM
redrumybronco's Avatar
redrumybronco
Hey Bronco86, so what ever happened to your injectors... did you get them cleaned?
