radiator woes
Old May 1, 2012 | 06:08 PM
whalebus2112's Avatar
whalebus2112
radiator woes
well Im trying to get my old,new ,truck road worthy so today I was changing the hoses and coolant and looked in the radiator and it looked like crap.
only 97,000 miles but the coolant looked like light brown water,not the gold,but watered down old *** coolant.
My question is is the factory rad. a good one ? If it is I will just get it rodded and cleaned for alot less than a replacement.
Also,how are the water pumps on these old motors? I have seen several ford impellers rotted away on there gas motors and if Im in there I wonder if I should go on and replace it?
Old May 1, 2012 | 07:02 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Not sure on the radiators, but as far as the water pump goes, i changed my origional @ 286k and the impeller looked new, the bearing was givin up. That may not be the case on yours with the grody green stuff. When i pulled my water pump and thermostat i was amazed to see just how clean everything was, and its stayed that way so far. Pop the rad cap and looks like brand new coolant, has around 14k on it now.
Old May 1, 2012 | 10:08 PM
Aune163rd's Avatar
Aune163rd
He is right...as long as you make sure your cooling parts are up to snuff...you will be fine forever...
Dr.B
Dec 17, 2008 11:46 PM
krankshaft
Aerostar
16
Oct 4, 2008 07:09 PM
RhinoScores
1983 - 2012 Ranger & B-Series
16
Feb 10, 2008 03:33 PM
PSNut
Jan 23, 2006 08:49 AM
RedTaurus94
Sep 24, 2004 09:04 AM
