Climate Control System doesn't work.. Help???
Old May 1, 2012 | 10:53 AM
JD603969's Avatar
JD603969
My 2005 Ford F-150 Lariat 4x4 5.4l V8. the climate control system will not let me lower the fan speed or let me change the airflow direction. and my heated seats will not work as well.. i looked at the fuse it was good.. and un-plugged the battery for 3 minutes.. any other suggestions?
Old May 1, 2012 | 01:41 PM
GwarForAll1021's Avatar
GwarForAll1021
Replace the switch. Mine was stuck on full blast. Simple unplug replug. Switch was cheap enough not to worry if it wasn't fix the problem.
Only thing I can see is if you have the digital climate controller. That thing runs 150.00 used when I looked.
Good luck.
Old May 3, 2012 | 06:01 AM
60DRB's Avatar
60DRB
If you have the "automatic" climate control, there is a self diagnostic capability. I know my brother's Taurus has that type A/C system. We ran the test, got the "fail code", replaced a faulty sensor ($25 from Tasca). Everything is like new now. I'm not sure if the test works the same as on his car, maybe somebody here has a little knowledge?
Here's the link to the Taurus thread if you want to give that a try...
A/C "reset"? - Taurus Car Club of America : Ford Taurus Forum
Good luck chasing the electrons... It is startling to discover how all the sensors are tied to differing systems that don't seem to be related.
Heirloom
Jul 2, 2024 10:01 PM
DrDerekReiser
1997 - 2003 F150
Mar 3, 2019 11:27 PM
Cjos1093
Escape & Escape Hybrid
Jul 22, 2018 02:41 PM
Marty1965
1997 - 2003 F150
Apr 29, 2018 06:13 AM
portsample
Jan 2, 2012 02:37 AM
