6.0 diesel coolant filter / scangauge
Hello all,
I have been doing some reading through the technical folders and 6.0 bible and noticed the coolant filter idea. I just bought an 04 f350 diesel and think this is a good idea. I found a kit for like 148 bucks, here is the link Sinister Coolant Filtration System / Filter Kit for Ford Powerstroke
Just wondering what peoples input was on this, I know someone said they pieced one together for like 50 bucks give or take, but I was thinking if the kit comes with everything I would need it might be a better way to go? Just looking for advice is all, and if all of this info. is somewhere else sorry for re-posting I just couldn't find much beyond what I've said here..
Also I read through many of these posts and a lot of the members seem to be a huge fan of the scangaugeII. I looked at that online as well, was thinking about picking one of these up as well, I read on some post here that you want to watch 2 numbers and make sure they don't exceed some figure, but I can't recollect what those numbers were, was wondering if someone could explain to me what exactly this unit is used for. Also I hear a lot about programmers, I am very new to the diesel world so I'm intrigued on what the benefits of the programmer is, I'm not so much looking for like 900 horsepower or anything like that, I just want to maybe increase mpg a little and keep everything running smoothe as glass.
Any input is very much appreciated! Thanks so much!!
-Steve E
-Steve E
id go to bullet proof diesel first, they are the guys who started to make the correct products to fix the 6.0 by the way
BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0
The ScanGauge is used to watch the engine coolant temp (ECT) and the engine oil temp(EOT). If the oil is 15deg or more hotter than the oil it is likely your oil cooler is clogging up and needs repair soon. If this condition is ignored a cascade of failures can happen that stretch head bolts, blow head gaskets, or even ruin your engine.
A tuner makes more power. If you get one for mileage gains you will be disappointed unless a 1-2 mpg was your goal. Some are hard on the transmission as well. Steer awar from "shift on the fly" tuners, many people swear by custom tunes and many say performance is awesome. I'm sure you'll get lots more info on that subject.
I have a Sinister coolant filter on my truck. Seems to work good. Installation was a breeze and it looks good.
Congrats on the new truck and welcome to FTE!
Yes a ScanGaugeII is a GREAT little device pick one up and will start checking your truck out when you can check the Numbers and give feedback
The Coolant filter kit is a Great Idea them kits Look good
My only problem Was I wanted a Coolant filter that Filtered the system Fast. In short my problem with the Kits is they reduce down to a Very Small line 5/32. the faster you filter will clean out the system. these kits reduce small very small
So I did my own coolant filter kept all the Lines 1 inch took the supply line off the same spot but took the return to a diffrent spot (return went to where the heater return tyes back in to coolant system) All my lines are Big ones and I drill the plastic peice out in the top of the Filter itself.
I choose this route because my coolant system was full of casting sand my oil cooler was plugged with it
My setup was also a little over 100.00 so not to much savings just better flow
But any coolant filter is better than nothing
Thanks for all the replies guys. Ok so it is definite then, a scangauge and this coolant filter setup is a go. Once I finally get my scan gauge running, what numbers should I post up here if I see, other than the eot and the ect. And just to verify what I don't want is an eot that is 15 deg. or more hotter than the coolant temp?
Hi,
Question about the setup for the Scanguage 2.
I just got F-350 in mid March. I added the coolant
filter kit from Sinister and a Scanguage 2.
Do I need to do any xguage stuff? I am not towing yet.
Or can I just set to show EOT ECT Battery Voltage and ????
Thanks in advance
Sean
Thanks in advance
Sean
There are a lot of useful Xgauges. When I got mine EOT had to be entered as an Xgauge. Several different ones for FICM volts. I like to monitor trans temp and fan when towing. ICP/IPR are good ones. You don't have to enter them all but at some point any of the Xgauges could come in handy. I would at least print a copy of the list and put it in the truck. If you don't have a copy here it is.
Sg2 codes w/values
Here is a partial list of Xgauges with Ford's values.
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. Check when cold
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT*
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
( not sure about the above)
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Sg2 codes w/values
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
NAM: EOT
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
TXD: 07E02209CD
RXF: 0462050906CD
MTH: 000100010000
NAM: SYC
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
Here's a video. I think one of our members posted it.
Entering codes on SGII
Scangauge II Xgauge entering - YouTube
Follow Rustys Lead He Has a GREAT start Going for you
And then if you get board go thru this thread theres a few more gauges and some GREAT info Guys
GREAT SCANGAUGE THREAD ON THE X-GAUGES
https://www.ford-trucks.com/forums/1...injectors.html
