recomendations on steering column
Old Apr 29, 2012 | 08:30 PM
slg51f1's Avatar
slg51f1
looking for suggestions on what steering column would be the best to use in a 51F1 build. the truck is going more the "street rod" direction .
Old Apr 30, 2012 | 08:32 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Welcome to FTE! Most use a GM or Ford column. I used a mid-70s GM column out of a Malibu on my 49. Length is perfect. DO NOT try to use a Mopar column...too many problems. Been there and done that!
If you have the bucks an aftermmarket Flaming River column for your specific application would be best...
Old Apr 30, 2012 | 10:30 AM
dawolverine's Avatar
dawolverine
I went with a billet specialties one, very pleased with it
Old Apr 30, 2012 | 12:54 PM
ZOOT's Avatar
ZOOT
If you don't use a aftermarket column, use a GM post '69 cause most aftermarket steering wheels will fit easier. I've heard the ones from an old GM van work well because they're a cleaner look. No mounting brackets etc.since most of the column is visable in the original interior.
Old Apr 30, 2012 | 04:57 PM
Jag Red 54's Avatar
Jag Red 54
I had a GM column in the truck when I purchased it. It had too many problems, so I replaced it with a Flaming River unit. Pricey, but nice! Jag
Old Apr 30, 2012 | 05:31 PM
AXracer's Avatar
AXracer
I have an Ididit paintable steel tilt column with my Toyota PS box and Grant wheel. I am quite satisfied with it.
What steering box are you using?
Old Apr 30, 2012 | 05:54 PM
slg51f1's Avatar
slg51f1
I am a FORD enthusiast, through and through, no GM or Mopar parts. someone had suggested a column from an Aerostar or Winstar.
using a 460 30 over with 10 to one compression, c6, mustang ifs, explorer rear, 8.8 posi.
the $$ not there for an aftermarket right now
suggestions
also looking for input on headers and exhaust
Old Apr 30, 2012 | 07:23 PM
Purple55's Avatar
Purple55
I used a 76 Torino w/ tilt. Probably a little hard finding one of those, nowadays.
My9fam
Dec 16, 2012 10:42 AM
Bigdaddy29384
Feb 11, 2005 05:11 AM
fatfenders
18
Sep 18, 2003 09:15 PM
mocky
Mar 1, 2000 06:30 AM
