Door A Jar light
Old May 1, 2012 | 11:26 PM
EXv10's Avatar
EXv10
Originally Posted by vtown00
I've sprayed DW, Liquid Wrench, and DuPont sprays in all of my latches and the light remains, annoying.
Clean your contacts on the hatch and slam it.
Old May 1, 2012 | 11:27 PM
EXv10's Avatar
EXv10
Joke;
When is a door not a door?..................actually a quiz.
Old May 2, 2012 | 10:21 AM
JOB1963's Avatar
JOB1963
WD-40 in the latches work perfectly. Lights out!!
Old May 3, 2012 | 12:04 AM
islander1808's Avatar
islander1808
Ok guys, here is how you need to approach it. Go to this link.
https://www.ford-trucks.com/forums/1...tton-menu.html
It is a dash diagnostic tool that will help you determine which one of your sensors is failing you. If you have a smart phone or wifi you can just take your phone/laptop out to the truck and follow the step by step and code by code instructions. I suffered from the same problem. Went through CANS of WD40 trying to "fix" the problem to no avail. After doing the diagnostic, that apparently Ford doesn't know of, I figured out that it was my rear passenger door. $50 and 20 minutes of my time later and it is fixed. Stop slamming your doors and hatches and buck up and make the fix. It seriously takes no time at all to pull of the door panel and get to the lock actuator. DO NOT TAKE YOUR TRUCK TO FORD TO HAVE THEM FIX IT!! The will charge you some ridiculous shop rate and this is one driveway repair that someone who has childlike mechanical ability can do.
Have fun fellas.
madsonp
Aug 31, 2012 12:22 PM
scriley63
1997 - 2003 F150
Jan 19, 2010 07:50 PM
bentheplumber
Jul 5, 2007 12:04 AM
68 351 bronc
Jan 21, 2004 01:52 AM
