Sponsored by: Real Truck
Dome light/ Door ajar
Old Jan 20, 2004 | 10:41 PM
68 351 bronc's Avatar
68 351 bronc
I have a 2001 SD 250 super cab, On a couple of ocasions the dome light has stayed on as did the door ajar light on the dash. The doors all shut tight and I can not find a switch in the door jam to signal the light.
Has any one had A similar problem?
Where is the switch, it may need adjusting? Inside the door?
Old Jan 21, 2004 | 01:40 AM
roughneck101's Avatar
roughneck101
The easiest solution is to get a can of WD-40 Or Misty and spray down at the bottom of the door latching mechanism. I had this same exact problem and I sprayed them till i had Misty coming out of the door latch and my problem was solved.
Old Jan 21, 2004 | 01:52 AM
Monsta's Avatar
Monsta
Sit. Stay.
BINGO!
