I Blue Sprung It
Old Apr 29, 2012 | 11:28 AM
GreenPSD's Avatar
GreenPSD
I Blue Sprung It
Well I finally installed the blue spring upgrade thanks to the procedure from Rusty Axlerod and tips from others. It was not bad at all, but I decided to make it more challenging. I did not remove the radiator hose or pull it down. The lowest screw in the housing was the worst. After wrestling with it for a few minutes, I was second guessing my decision not to remove the hose, but I was able to get it out with a u-joint. Putting the new cover on, I realized I had an adaptor to put the torx bit in a ratcheting wrench. That made it a breeze. So it can be done. Things are so much easier when you use the right tools. Of course I have the plastic intake tube and as others suggested, I heated it up to remove and put back on. I took it for a drive and it may run a little better but definately not worse.
Old Apr 29, 2012 | 01:21 PM
kidoo's Avatar
kidoo
Did it too, but with the housing removed. Did not try the truck yet, still waiting for parts for the turbo.
Rod Jr.
Jan 1, 2019 03:29 PM
William Mark Brown
15
Oct 7, 2015 10:43 PM
Snuggyworm
May 13, 2013 08:38 PM
teppler
Jan 22, 2010 07:23 AM
99PSDCREW
Oct 13, 2004 12:25 PM
