what is a CCV kit?
Old Apr 28, 2012 | 09:09 PM
4x4countryboy's Avatar
4x4countryboy
what is a CCV kit?
what does this do?
Riffraff Diesel: RDP CCV Kit
Thanks!
Old Apr 28, 2012 | 09:14 PM
joeyd61's Avatar
joeyd61
it dumps the crank case vent to atmosphere..stock set up puts it back into the turbo and into your intercooler..thats why the boots seap oll. I vented mine back toward the rear axle.be sure there are no dips in the line or oil will stop the CCV up...
BigAlsPSD's Avatar
BigAlsPSD
It keeps the oily mist from going into the intake keeping the boots and charge tubes a little cleaner.
Old Apr 28, 2012 | 09:19 PM
JonathanN's Avatar
JonathanN
Plus, as the oil works it's way between the intercooler boots and their flanges, they get to where they don't seal as well, if at all. They can also bow off, too... good boost is pretty important to get the most out of the truck. If you have boost leaks, you have a dog of a truck.
Old Apr 28, 2012 | 09:26 PM
4x4countryboy
Thank you! was just curious
Old Apr 29, 2012 | 05:44 AM
SSSimon's Avatar
SSSimon
The oil film that ends up inside your IC kills its ability to cool your incoming air.
Old Apr 29, 2012 | 08:20 AM
mueckster's Avatar
mueckster
That's why I blow mine out occasionally. If you know what I mean?
BTW, I have my CCV routed thru a trap back to the stock CCV connector. It doesn't remove all the oil, but helps. My intake air temps at the spider are ~10 degrees or less above ambient with my larger IC.
aocabrown
16
Nov 14, 2007 10:02 PM
davidw221
Jul 29, 2007 04:37 PM
bkvanbek
Jan 14, 2007 04:52 PM
kilroy99
Jan 15, 2005 12:58 PM
Pablo69
Oct 7, 2004 09:25 PM
