check Fust 16 (15 Amp max) as stated above, if ok check BEHIND the cig tray (slides out, just forget exactly how to get it out) and check wires (should IIRC be blue) and see if that has been cut (say to splice a CB in previously) if cut, repair it (properly please)....
if all of the above is true and done please listen to your truck and don't smoke...its sending you a message....
To pull the ashtray out completely, simply pull it out to the end of the track and give it a hard tug...It'll pop right out...
As for the wiring...Most times, the wires simply need to be plugged back in..
1 is a spade connector, and the other is a terminal/lug style...They don't interchange...
I just had mine out today. It looks like it's pretty easy to pinch those wires in that socket so make sure they've not been pinched like mine. I'm going to have to do some r&r on it to fix it.
