??Welded Fuel Pump??
Old Apr 28, 2012 | 03:30 PM
JAFFAR3869's Avatar
JAFFAR3869
so last week my fuel pump on my 49 f36cyl went bad. I ordered a new pump and just a few moments ago took the old one out. someone welded the old one?? I'll attach a link below for pictures. I figured someone must have had to compensate for a worn cam, so i stuck my finger in there and the cam seems fine, however i have not spun the engine over yet and checked the cam in various places.
This is very strange to me. Should I do the same with the new pump???
All help is greatly appreciated.
Pictures by JAFFAR3869 - Photobucket
-Jeff
Old Apr 28, 2012 | 03:46 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
There should be no reason to weld your new pump. That weld looks like something Farmer McGuyver did to get back home after rabbit hunting with a BB gun...
edit: Does the arm on the new pump look the same? minus the welds?
Old Apr 28, 2012 | 04:13 PM
JAFFAR3869's Avatar
JAFFAR3869
yes it does, just no welded part attached. not as wide of an arm
Old Apr 28, 2012 | 04:22 PM
4tl8ford's Avatar
4tl8ford
Could someone have cottiedbobed a different year pump on there - I cant see any reason for a proper pump to need so much compensation - Check the angle of the arms
Old Apr 28, 2012 | 04:24 PM
AXracer's Avatar
AXracer
My guess is that is not the right fuel pump for the engine and the piece was added to make it work. Have you checked the block numbers to be sure a different year engine wasn't installed? I wouldn't modify or install the new pump until you solve this mystery. Seems I recall another topic a while back about a similar problem?
Old Apr 28, 2012 | 04:29 PM
AXracer's Avatar
AXracer
There is quite a bit of wear on that cootie bobbed arm. I'd pull the engine front and inspect the cam. If it's been worn thin the arm could break thru and damage the engine.
Old Apr 28, 2012 | 06:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Electric pump time....
Isn't it possible on those engines (or maybe it's 215's?) to install the pump upside down?
Old Apr 29, 2012 | 09:06 AM
JAFFAR3869's Avatar
JAFFAR3869
I was able to turn the engine over and stuff my finger in the pump hole to feel the cam. the cam feels ok, seems to have even wear across that area. I was expecting a deep groove of some sort. I dont see the need for the added piece.
Perhaps I'll put the new pump in and see what happens??
Old Apr 29, 2012 | 09:27 AM
JAFFAR3869's Avatar
JAFFAR3869
this pump works with 48-51 6cylinder engines, and its identical to what I took out. Ill scoundrel the old pump for a number maybe. Perhaps this is a v8 pump. they look similar.
Old Apr 29, 2012 | 10:05 AM
AXracer's Avatar
AXracer
It's pretty obvious the old pump was not the right one, so if the new one is identical to it without the extra piece, it too is wrong. Matching the part number of the (wrong) pump won't help either. IIRC from the other topic, there are two nearly identical pumps except for the arm angle. You might try doing an advanced search on this forum for "fuel pump" to see if you can find it.
Agnitoood
Jun 9, 2018 09:15 AM
fancyvern
Apr 22, 2017 02:32 PM
Onus
Sep 18, 2012 07:03 PM
jwtimme
Apr 10, 2007 10:00 PM
bobj49f2
Jun 28, 2005 11:50 AM
