summit fuel pump
Old Apr 8, 2007 | 03:39 PM
jwtimme's Avatar
jwtimme
summit fuel pump
I just installed a new fuel pump from summit and now no fuel. has any body used these pumps and had any problems. I'm wondering if the in and out ports are reversed on these pumps.
I should have bough the holley.
Old Apr 10, 2007 | 10:50 AM
Freightrain's Avatar
Freightrain
Mechanical pump?
Did you "pump" it by hand and see if you get suction on one port?
Does the arm match your original arm exactly. There are variations that look kinda right, but actually never gets to eccentric on cam and thus NO pumping action after you install it.
Old Apr 10, 2007 | 05:45 PM
jwtimme's Avatar
jwtimme
I figured it out, the intake and out let were reversed, I had talked to the tech people at summit before I installed the pump and they told me wrong. The pump is built to go on the passenger side a car. Summit’s guys must not be informed the pump sits on the drivers side.
Old Apr 10, 2007 | 09:57 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by jwtimme
I figured it out... Summit’s guys must not be informed...
...and neither are the guys setting up the parts applications on the webpage. :)
You figured it out yourself and that's what i found, do your homework with the manufactures etc before buying from Summit.
Alvin in AZ
Old Apr 10, 2007 | 10:00 PM
Freightrain
There aint a Ford built with the pump on the passenger side! Dang Chevy guys giving you ALL the wrong information!!!!
v8xploder
1978 - 1996 Big Bronco
Nov 3, 2009 10:51 AM
gtex
Dec 16, 2008 04:59 PM
jamies460
Mar 15, 2008 05:52 AM
krunker
Modular V8 (4.6L, 5.4L)
Mar 3, 2004 12:25 PM
superswamper
Jun 12, 2003 09:37 AM
