50 cent mod ? (Now Ive Got Problems)
Old Apr 29, 2012 | 06:06 AM
Pitcrw6's Avatar
Pitcrw6
Well I guess I misread or was just told wrong about the clips coming on 02 & 03 trucks. Sorry about that.
Old Apr 29, 2012 | 10:15 AM
Ponyboychris's Avatar
Ponyboychris
Originally Posted by endobear
Installed a new injecter harness and the International clips/shims..
Same thing happened when Bill (BillyBob69) and I were working on his truck. He has an E99 and when we tried to insert the quarter into the harnesses, they were so brittle that we broke off the clips. He ended up replacing both harnesses and valve cover gaskets as a result.
Old Apr 29, 2012 | 12:42 PM
endobear's Avatar
endobear
Geuss I should consider myself lucky that I only had to replace the harness.
Old Apr 29, 2012 | 12:58 PM
1L243's Avatar
1L243
Did you say when you first went in there it had the plastic wedges and they were loose? I wonder if using a heat gun to soften up the plastic clip before inserting the quarter would be a good idea?
Old Apr 29, 2012 | 01:42 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
No problem bro! I had heard the same thing but when I removed the valve covers to replace the glo plugs there werent any clips so I used the quarters.
Old Apr 29, 2012 | 03:15 PM
endobear's Avatar
endobear
Apparently someone had been into the valve cover at some point before I owned the truck (bought the truck with 33000)and put in the 17$ shims.
Old Apr 29, 2012 | 04:07 PM
1L243's Avatar
1L243
I have the wedges in my truck but they should not be loose...
Old Apr 29, 2012 | 08:22 PM
Ponyboychris
Might have been in to a dealer for an issue and they can't put quarters in there...
Old Apr 30, 2012 | 08:30 AM
endobear's Avatar
endobear
They where only loose after I unplugged the harness.
NCMillwright
2009 - 2014 F150
Jan 6, 2017 04:12 PM
RobertJohn
Mar 21, 2014 06:14 PM
Diablo540
Mar 3, 2014 05:24 PM
oasisbenk
Oct 31, 2011 07:26 AM
97haymachine
Apr 19, 2010 03:16 PM
