Southern engineering? How about a 25k hitch, gusseted on 4 corners and attached with grade 8 bolts and self locking nuts. Better than the thing Reese sells.
Apologies then, you did it right --- have seen too many half-a.. jobs in my short time here
Originally Posted by Sarge261
Thanks for reading,
The only complaint I have is I will have to remove the tail gate, my wife will smush me between the truck and trailer as the tail gate has to be 1/2 way down in order to not hit the trailer.
Too bad you're not close enough to get that louvered tailgate I used for a bit while I replaced my damaged one
no tailgate drop - just drive right on in !
or, would this work for you,
how about the old school method of putting blocks under your front jacks to give you more height ...
I dont want to start a war in my thread, but I wil say this, the Goose Box is heavier than the pin box that was on the trailer, its made of thicker plate. If I knew it wouldnt void the warranty then I would have made my own adapter as well, but with a new trailer I wanted to keep the warranty on the frame.
Also the Reese Goose Box is a real nice unit with a lot of technolgy built in.
As for the gates, I will just remove mine because the bed wont be secure with a 5th wheel gate anyway so if I remove it there is nothing to steal.
I am a bit confused .....
I lower the tailgate fully.
Backup and connect to the king pin. (yes, 5th wheel)
latch & lock
Raise tailgate. (the tailgate isn't very far from contacting the front of the trailer, but it doesn't.
Soooo With the gooseneck configuration..... you can't fully lower the tailgate and backup to the point that the goosebox is over the ball without the tailgate hitting the trailer ?????
I dont think I can lower the gate with the 5er hooked up. I didnt try it, but when we were hooking it up at the dealer the guy looked nervous like it was going to hit. I can definatly try it on my own, but I iwll make sure smeone is there to watch.
And yes, my wife would definately pinch me between the truck and trailer no doubt in my mind.
