Her Spread
if so cut it like this
this from Roasted thanks BUD
I cant paste the pic so here is a Link to it checkit out Notice how Roasted cut it right down the Coolant PORTS this where it plugged. And the middle of cooler was Clean
Great Oil Cooler clogged Pics all clean except the Inlet/outlet
https://www.ford-trucks.com/forums/1...l#post11560587
others may have a Bad Temp sensor thrown into the mix
when I drive at the same conditions as you Im a 6-8* spread and it favors 8* I only have 15K on this oil cooler
in the city I get an average of 2-4* spread
Now that right there is Funney
As an example returning from Az. my eot started running 7 to 8 degrees cooler than my ect. Took it to Ford and they said it's inside allowable parameters. They didn't care that the eot suddenly started running cooler than the ect. Been like that since December. Both sensors are within a degree after cold soak. Since I still have 4 years esp warranty left I said OK and drive it that way. If I keep it till it's out of warranty I'll replace the eot sensor.
