radio interfearence from tuner
Old Apr 25, 2012 | 09:37 PM
red 1997 powerstroke's Avatar
i have a 1997 f 350 and i recently installed a f5 dptuner on my truck now i get terrable radio reception due to the tuner i have tryed a antenna booster, putting ferrit beads on the tunner cable, wrapping the tunner cable with tin foil and rapping a wire around the tuner cable and grounding that wire all with no succes the truck currently has a pioneer radio in it i have been trying to fix this problem for quite some time now and have run out of ideas any help would be gratly apreciated thanks luke
Old Apr 25, 2012 | 10:50 PM
strokin'_tatsch's Avatar
strokin'_tatsch
This has been a hit and miss problem with Moates chips for years. DP-Tuner uses Moates chips obviously.
Does yours have the old style ribbon cable or the newer shielded cable? I'm assuming it's the newer cable.
The only things i would know to try for radio interferance would be the ferrite beads and/or tin foil over the cable and that didn't work for you. You need to call DP-Tuner and ask them for a solution. If no solution comes about, I would bet that you can sell the DP-Tuner and get a custom chip from anyone else that uses the TS style chips and the problem will go away.
Old Apr 26, 2012 | 07:20 AM
Talyn's Avatar
Talyn
There is a solution thread to this up in the NBS 7.3 forum IIRC>
Old Apr 26, 2012 | 09:56 AM
strokin'_tatsch
Got a link???
Old Apr 26, 2012 | 10:24 AM
DIYMechanic's Avatar
DIYMechanic
I know that I have heard a lot of guys say that re-routing the wire to the switch on the tuner will help the issue. Trying to keep it away from the radio and antenna wiring as much as possible is supposed to really help.
Old Apr 26, 2012 | 06:54 PM
radio interfearemce
ok cool now ho do i get to the nbs 7.3 forum where is that located?
Old Apr 26, 2012 | 06:56 PM
DIYMechanic
Here is a link:
1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Although you're technically in the correct section for a '97...
Old Apr 26, 2012 | 08:32 PM
thanks for the link i just went to it but i cant seem to find that solution thread mentioned above is there any certain way im supposted to be lookin for it?
Old Apr 26, 2012 | 08:40 PM
Talyn's Avatar
Talyn
Gimmie some time to ask around about it.
Old Apr 26, 2012 | 08:46 PM
Talyn's Avatar
Talyn
I'm not having any luck finding it either, and the 2 guys I asked never had the issue, so they didn't have the link.
I know its around.
If you post up in that forum, they might have the link for ya.
Old Apr 26, 2012 | 09:57 PM
ok thanks for looking around i wil post it in that forum and
see if i get any luck thanks again
Googs81
Mar 9, 2020 11:47 PM
oracle
2009 - 2014 F150
Jun 3, 2017 12:15 AM
jim collins
17
Jan 31, 2014 12:39 PM
78Ranger_GARedNeck
Jun 6, 2008 11:39 AM
Muktown
Feb 21, 2007 06:26 PM
