fuel pump problems
Old Apr 25, 2012 | 11:32 AM
olred85's Avatar
olred85
fuel pump problems
hi, i have been checking this site out for a couple days nowlooking for solutions and finaly joined. i have an 86 f150 with a 302, mpfi, and dual tanks. after getting it home i realized that the fuel pumps on the rail, high pressure, and the front tank are hard wired to the fuse block. i have been reading alot about this somewhat typical seeming problem and have narrowed it down to afew things but not sure where to start diagnosing. for starters i an hear the fuel pump relay opening and closing so i know that has power. if anyone knows where i should start diagnosing the problem after this i would greatly appreciciate it. i believe it has something to do with either the tank selector switch because when i switch it to the rear the front still works but it is also hard wired so its hard to say.
Old Apr 25, 2012 | 11:51 AM
Franklin2's Avatar
Franklin2
What's your exact problem, will the truck run? All I got out of your post was the pumps are hard wired. Is that your problem, they run all the time?
Old Apr 25, 2012 | 08:22 PM
olred85's Avatar
olred85
the truck does run, the fuel pumps are hard wired to key power in the fuse block. i would like to get them working under the trucks original power source because right now if i want to listen to the radio i have to have the truck running. plus the fuel pump is getting full power so it is slowly burning it out.
BrianJoyner93
Dec 29, 2018 01:09 PM
Powerstroke-7.3
13
Dec 29, 2009 02:45 PM
tazmania18235
Jul 22, 2005 07:00 AM
remmers
19
Oct 18, 2003 01:46 PM
