Throw bearing grinding?
Old Apr 24, 2012 | 09:33 PM
66gpw's Avatar
66gpw
My 92 F250 with a 7.3 and 5spd Standard 4x4.
I notice today that everytime I shift that I get a bit of grinding as I release the clutch at all gears. You can feel it even in the shifter. I tried shifts at different RPMS but it still happens. The only things that seems to help is slowly release the clutch pedal stop near the top of release and slowly release and it may not happen 1/2 the time.
I suspect the throw bearing is maybe grinding against the input shaft everytime the slave cylinder releases it.
So do you agree the bearing maybe gone. If so, my next task is removing the trans to replace it. I never done a 4x4 trans before. So where can a person find instructions or guidance to remove and reinstall besides the the Haynes manual that does not cover enough of this type of work. Is there an online site that I can get this info.?
Old May 3, 2012 | 09:24 PM
tecgod13's Avatar
tecgod13
Only difference with a 4x4 tranny is that it has a transfer case mounted to it. Basically, you have another driveshaft to remove, the linkage for the transfer case, and the transfer case itself. Its just a little more work, not really anything difficult. Some people drop the transmission and transfer case together as one unit. If you have a jack that can handle it thats fine, just harder to maneuver.
The throw out bearing doesn't actually touch the input shaft. It rides on the 'quill', basically a hollow tube over the input shaft. It can hang up on the quill, but the rotating part contacts the pressure plate, the bearing itself doesn't spin on the quill.
Old May 3, 2012 | 10:21 PM
66gpw's Avatar
66gpw
It always has a bit of a grind when the clutch is nearly out. So it sound from wht your saying is that it grinds against the pressure plate. Not the shaft. ?
Either way I will have to solve this before I get seriuos damage done.
D & D
Jul 29, 2014 07:36 PM
TruckNorris250
Feb 19, 2014 08:42 PM
hungagain
Jan 23, 2005 07:48 AM
cryptonik420
Oct 31, 2003 09:02 AM
91pcup
Jun 11, 2002 12:42 PM
