So I started taking everything apart in order to replace oil cooler, stc fitting, standpipes etc. The hardest part was not removing the turbo but removing the FICM those connectors are a PITA.
Anyway other than breaking the fuel filter cap When I popped off the wire retainer for the injector plug it went flying and I can't find it. Is there a part # for these?
You can buy them. Just go to the ford house and pick one up. I have had to replace a few of them on trucks I have worked on (they were missing when I got the trucks in the shop).
As stated above, next time don't remove them, just push them in and pull the connector off that way. Much easier.
I have a few laying around the shop if your going to be down for a few days. I can send one out thursday no charge if you want it.
Thanks Texans, I'm going to run by the ford shop today and see if they have one, since I have to get a new fuel filter cap anyway. If they don't have them I will be shooting you a PM
Blade, I was never good at electrical connections too many different types
