351M starter replacement
Old Apr 25, 2012 | 10:40 PM
78fordwheelin's Avatar
78fordwheelin
well the solenoid clicks so wouldnt that mean its good?
I tried jumping it today, i dont even get a spark, but when I connected the jumper cables from my running car to my battery and jumped it with screwdrivers, bigass sparks.
Let my trucks battery charge for a good 10 minutes, came out took the jumper cables off, and once again not even a spark.
Old Apr 25, 2012 | 11:12 PM
hasteranger's Avatar
hasteranger
sounds like a dead battery to me??
Old Apr 25, 2012 | 11:19 PM
78fordwheelin
yeah i wish i could just get it to my shop at school somehow. we got a nice *** snap on charging system/battery tester/charger.
oh and i took the single bolt out holding my starter on, and it still wont come out.....
Old Jan 11, 2018 | 05:45 PM
agstr's Avatar
agstr
starter problem
I replaced mine only to find out it was the insulation on the power cable was melted causing it to ground out -- replaced and located the cable and it and it started without issue
Old Jan 12, 2018 | 02:26 AM
1TonBasecamp's Avatar
1TonBasecamp
Good find agstr. Well, a good find AFTER you spend money on the new starter, but hey, at least you found the problem.
And got a new starter out of it for your troubles.
If your other cables are old too, might just change them out (or at least keep your eyes on them for trouble) because they're as old as the other one.
Admittedly the starter cable likely takes more of a beating, being down low in harm's way so to speak. But the upper ones get pretty crusty too.
Good luck. Hope the new part lives up to it's expectations too!
We see a lot of new stuff fail quickly unfortunately. Which is why I mention it.
Oh, and way to search back in the archives too! Did you google it with this site listed or something like that? Or were you just digging deep?
Paul
Old Jan 12, 2018 | 11:32 AM
Bulldog187th's Avatar
Bulldog187th
This is funny, (not your problem) I just came across a video about the starter solenoid this morning . I just got done posting it. This might help you.
https://www.ford-trucks.com/forums/1...oid-video.html
I see you found the problem , You still might want to watch it for next time
camperspecial65
Nov 24, 2008 10:12 PM
wyazel1
Sep 15, 2008 05:11 PM
Chris_ce
Jun 12, 2005 02:03 PM
aunchman
Jul 29, 2003 09:19 AM
