351M starter replacement
Old Apr 24, 2012 | 01:32 PM
78fordwheelin's Avatar
78fordwheelin
Went out to my truck this morning, and all I got was a click when i turned the key. So looks like its time for a new starter. I was gonna pull it and go get a new one real quick, But i cant figure out how to get the top bolt out. The truck came with headers and they couldnt be any more in the way.
Anyone else with headers on their 351 know any way to get to it other than taking the headers off?
Old Apr 24, 2012 | 02:39 PM
bkohne1's Avatar
bkohne1
I have the same motor (with headers) in my 77 f250 and I am able to reach the bolt closest to the engine from underneath and the other bolt (closest to the frame) from the top side.
Old Apr 24, 2012 | 05:24 PM
mark a.'s Avatar
mark a.
Did you check your battery ? Try beating on the end of the starter with a hammer if jumping it doesn't work. If you get it running check the charging system, see if it's putting out anything.
Old Apr 24, 2012 | 07:27 PM
JBradley500's Avatar
JBradley500
What's clicking? Is the solenoid clicking?
Old Apr 24, 2012 | 07:33 PM
78fordwheelin
Gave it a good beat, tried jumping it, and tried a different battery that I knew was good. Same result. And yes the solenoid clicks
Old Apr 24, 2012 | 07:34 PM
78fordwheelin
And the alternator is new, although for some reason my headlights pulse when the engine is running
Old Apr 24, 2012 | 07:54 PM
critterf1's Avatar
critterf1
"Jump" the solenoid and see if it starts.
Old Apr 24, 2012 | 08:07 PM
78fordwheelin
Can I jump it from the wire that attaches to the relay? I can't fit jumper cables past the headers
Old Apr 24, 2012 | 09:51 PM
hasteranger's Avatar
hasteranger
I think he is saying jump it right at the solenoid. I usually just use a screwdriver or two to test the solenoid. Just don't use one you like a whole lot, it can melt the end. lol.
I had a 351 and now a 460 and I have no problems getting to the bolts with a standard wrench. i can't get a ratchet on either on, but I can get a wrench. I do not have headers, though.
Old Apr 24, 2012 | 11:02 PM
cdntthinkofausername's Avatar
extension and ratchet i thought it was impossible to but it just takes a long time
Old Apr 24, 2012 | 11:58 PM
78fordwheelin
how do you test it with a screwdriver?
Old Apr 25, 2012 | 10:37 AM
hasteranger
This is the general technique, I'm using a pry bar instead of a screwdriver on the battery because thats what I had laying around when I walked outside:
And this is the likely consequence for your screwdriver, although this is a cheaper than dirt one I keep in the toolbox for just such a purpose (one of my trucks had a finicky solenoid for a while):
Old Apr 25, 2012 | 11:03 AM
78fordwheelin
Ohhh okay so you just use the screwdrivers to jump the battery positive to the output on the relay? Its kinda hard to see on my phone but that's what it looks like
Old Apr 25, 2012 | 04:06 PM
monsterbaby's Avatar
monsterbaby
if your going to directly bypass the solenoid use jumper cables. attach to the output side of the solenoid and then other end to the positive of the bat.
Old Apr 25, 2012 | 10:13 PM
hasteranger
Too cumbersome. Use jumper cables and youre likely to short them out against the fender. From experience. Just use screwdrivers. They are just as thick and conduct 12 volts just as well as jumper cables, and they will flow more than enough current to start the truck .
