1978 - 1996 Big Bronco
Loose Steering
Old Nov 22, 2001 | 12:57 PM
Mil1ion's Avatar
Mil1ion
Loose Steering
Old Nov 23, 2001 | 12:34 PM
cyberdr2's Avatar
cyberdr2
Loose Steering
I just purchased a 93 Bronco 5.8L with 31x10.5 tires. The steering on the truck seems to be a little loose (radial arm bushings have been replaced). I can feel about two inches of play to the right and left of center on the steering wheel. This in turn causes a bit of wandering on the road. Is there a way that I can tighten or adjust the steering box? What other things might I check for this symptom. Is there a steering stabilizer I can add-on that will give me more control and tighten up the steering? I have also heard about a Ford TSB cdrom. Can anyone point me in the right direction on where I can find one? Thanks for your help.
Old Nov 23, 2001 | 03:13 PM
kellyb's Avatar
kellyb
Loose Steering
when the tie rod ends are worn that will cause steering to be like what your talkin about. they dont cost much,you might be able to replace them yourself but will need an alignment afterwards.
