Blinkers-help
Old Apr 26, 2012 | 09:59 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Likely the headlight switch is the culprit for the dash lights not working. You turn the headlight **** counter-clockwise for full illumination and past to the click to turn on the dome light.
The dash bulbs could be bad also but be careful removing the Speedo cluster; some of the plastic wasn't good and they crumble.
The headlight **** is released by pushing down a spring pin on top of the switch. Reach up under the dash and feel for it above the main block of the switch.
The wiper **** has a spring clip on the backside of the know it's-self.
On the back side of the dash bezel above the headlight/wiper holes is a light clip attached to a plastic fragile arm; squeeze the metal holder and it comes right off.
BobL
Feb 6, 2011 08:25 AM
sandcrab
Jul 15, 2006 10:45 PM
scurbiedog
1978 - 1996 Big Bronco
Aug 10, 2005 09:29 AM
nycanc2000
1983 - 2012 Ranger & B-Series
Oct 26, 2004 12:10 PM
CRJ900
Mar 28, 2004 08:31 PM
