351m or 400 identification
Old May 1, 2003 | 05:31 PM
Ford Truck Racer's Avatar
Ford Truck Racer
I am installing a motor in my brothers truck and he said it had a 351m. But after looking at it, it looks more like a FE. This is a 78 F-150. So if someone could post a picture of what a 351M would look like and where I could find a number stamped on the the block this would help a lot. Thanks.
Old May 2, 2003 | 04:42 AM
ferguson777's Avatar
ferguson777
If no one responds to this note, try this;
There is one of the Bronco sites that has an article on the history, care and feeding of a 351M/400M. If you do a search on the WWW using something like " 351M AND performance" you'll probably find it. It has some pictures of what they look like as I recall.
Additionally, the FE has 5 valve cover bolts per head, the M's and C's have 8 ( and the W's have 6). The M's also have the dipstick going into the pan rather than the block - not sure what the FE's have.
Later,
Old May 14, 2003 | 08:29 PM
havi's Avatar
havi
I'll have the Roast Duck
thermostat housing is a tell-tale sign determining what type motor you have. Also, the FE motors have their intake manifold -to- head-surface more significant than the 400...hope this helps
Old May 14, 2003 | 11:54 PM
Ford_Six's Avatar
Ford_Six
If the intake forms part of the valve cover mating surface, that's an FE. If not, it's a 351m or 400 (most likely). If it is an FE, that's not stock for that truck. Also, if it had a big block before, an FE won't fit, they used a different bellhousing.
Old Aug 22, 2003 | 09:08 PM
mindless's Avatar
mindless
on a 351m look on front end of the heads if it is a 351m it has a m stamped on it.
Old Aug 26, 2003 | 10:10 PM
Ecuri's Avatar
Ecuri
And the FE's use a rocker shaft whereas the M's are pedastal mount valve train.... and the valve covers on the FE come to an angle on top rather than a flat. And the FE has a seperate timing cover rather than part of the block. Pretty sure, Is that all correct?
Old Aug 28, 2003 | 10:04 PM
Brian460's Avatar
Brian460
And they stopped using FE motors in '76, so unless somebody swapped it, it is probaly a 351M/400
A 351M/400 has a diagonal bolt pattern on each exhaust port and a FE has a vertical pattern on each port.
Also true about the timing cover.
Old Aug 29, 2003 | 08:27 PM
pfogle's Avatar
pfogle
On the valve cover there should be an identification sticker that will say 351/400 then undeneath it will say 351 or 400 not both, it might give the liter 5.8 vs 6.0
427mike
Apr 4, 2012 07:59 PM
FordFETruck
Oct 12, 2011 09:42 PM
Shorty 66
Jan 6, 2009 08:58 PM
bhabben
20
Sep 18, 2003 04:01 AM
The Tree
1978 - 1996 Big Bronco
Mar 22, 2003 12:33 AM
