Possible FICM ISSUE
Old Apr 22, 2012 | 10:29 PM
knsahara's Avatar
knsahara
Possible FICM ISSUE
WORKING ON '06 , I THINK IM HAVING SOME FICM PROBLEMS SO FAR CHECK ENGINE LIGHT HAS BEEN ON FOR A FEW WEEKS WITH INJECTOR CIRCUIT LOW ON ALL CYLINDERS. FINALLAY LED TO A NO START CONDITION. HAD ABOUT 21 VOLTS ON THE FICM AT STARTING. TOOK IT OUT RESOLDERD ALL 16 JOINTS (EVEN THOUGH DIDN'T REALLY SEE ANY CRACKS.)PUT IT BACK FIRED RIGHT UP DROVE ABOUT 30 MILES . THE NEXT DAY ANOTHER NO START CONDTION AND INJECTOR CIRCUIT LOW CODES AGAIN. TRYING TO DECIDE WHAT TO DO AND DIRECTION TO GO IN. SHOULD I JUST PULL THE FICM AND HAVE SENT OUT? I JUST DON'T REALLY FEEL LIKE RESOLDERING AGAIN WILL HELP.
Old Apr 22, 2012 | 11:22 PM
BLADE35's Avatar
BLADE35
Well Bro FICM needs to be professionaly rebuilt
The thing here is you were down to 21volts thats WAY LOW and when you pulled it open and DIDNT see any cracked soilder joints oddds were a simple resoilder job wasnt going to cut it.
Time to Pull the FICM out and send it to ED
www.ficmrepair.com
He will get yopu fixed right up it will end up a better part than a New FICM would as they still have the Power supply problems
ED is the MAN does great job at an Honest Price
And Now that we talked about the FICM while its off getting fixed Get your Batterys Load tested and bench test alternator. and then Clean ALL Battery Cables all of them Grounds everything even where the grounds meet the engine block(by the A/C Pump) and the Frame (By the Power Steering Pump)
Just Make shure the charging system is 110% as problems here will Take out the FICM FAST
Old Apr 22, 2012 | 11:34 PM
BLADE35's Avatar
BLADE35
One thing Before you go to all that trouble is check the FICM Ground wire it comes out the FICM Harness right next to the Unit and goes to the Back Intake Manafold Bolt its the One with a LOOP End
If you didnt mess with it its probably on but dont hurt to check it
Old Apr 23, 2012 | 09:28 PM
knsahara's Avatar
knsahara
Ok , Thanks for the advice Im gonna go ahead and send it in. Ill post follow ups.
Old Apr 29, 2012 | 12:34 AM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
We'll take great care of you!
Thanks for the props, Benny!
Old Apr 29, 2012 | 08:11 PM
knsahara's Avatar
knsahara
Ficm repair went well, got unit back very promptly. My advice would be if your trying to resolder your self and you dont see any cracked joints just leave it alone and send it in because if you mess with it or work on it you have to pay $50 more .
Old Apr 29, 2012 | 08:18 PM
FICMrepair.com
Former Vendor
Happy to have been able to take care of you!
Old Apr 29, 2012 | 10:00 PM
knsahara's Avatar
knsahara
Old Apr 29, 2012 | 11:23 PM
steelhead2's Avatar
steelhead2
Ficm repair are good people.i still gotta pull mine and send it in for warranty work. I have no doubt ed will fix me up. And youre right knsahara, much easier to let ed do the soldering and save the 50 bucks.
Old Apr 29, 2012 | 11:50 PM
FICMrepair.com
Former Vendor
Please do that, Steelhead2! I'm very curious to see what happened with it. Regardless, we'll take great care of you.
Evan06
Oct 8, 2017 06:45 PM
Tom14032
Feb 10, 2016 06:52 AM
hobbystock98
Apr 15, 2013 02:03 PM
Chemfrk
Nov 19, 2011 04:00 PM
35l911
General Automotive Discussion
Dec 8, 2009 08:07 PM
