Standard 68 grille
Old Apr 22, 2012 | 09:25 PM
racinray's Avatar
racinray
Standard 68 grille
Has anyone ever considered or chrome powdercoated one??Just thinking about doing mine.Concerned about saving all those plastic inserts holding the headlight buckets can new ones be purchased?
Old Apr 23, 2012 | 12:32 PM
bmuhlbach's Avatar
bmuhlbach
I seen one and talked to the owner of 1 68 truck that he had stripped the paint and had it chromed it looked really good.Plastic clips check Dennis Carpender
Old Apr 23, 2012 | 01:32 PM
racinray's Avatar
racinray
Who is this Dennis Carpenter and how do I find him?
Old Apr 23, 2012 | 07:48 PM
bmuhlbach's Avatar
bmuhlbach
Dennis Carpenter Ford Car, F-100 Pickup Truck, 8N, 9N Tractor and Cushman Scooter Restoration Parts
he is a supplier to buy parts from there is also some that sponser this web site.
Old Apr 24, 2012 | 01:13 PM
money pit 69's Avatar
money pit 69
I am considering having my grille for my 69 powder coated also. I have tried everything I have heard of to make it shine. No LUck. Someone said it is anodized so it won't shine until its removed. So maybe powder coating is the answer. Money Pit 69
Old Apr 24, 2012 | 01:33 PM
gangstakr's Avatar
gangstakr
In order to get any aluminum grille to shine or to be powder coated (I don't know if aluminum can be powder coated) the anodizing needs to be stripped off.
"Quote from" racinray,
Which plastic pieces are you referring to? The ones for the buckets are headlight adjustment screw assemblys. Then there are four plastic nuts for the headlight bezels/doors. Which ones are you concerned about? All of these can be bought.
LMC shows nylon nut-bezel for headlight bezels at $0.35 you need eight.
their part number is 40-0830
Headlight adjuster assembly LMC part number 40-0956 sell price $2.95
Old Apr 24, 2012 | 01:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7TZ-13032-B .. Headlamp Adjustment Screw & White Plastic Nut Assembly / Obsolete / 5,582 (!) available NOS / Carpenter has 5,255 of the puppies = 800-476-9653.
Applications: 1967/69 F100/750 / 1969/74 Econoline.
376309-S .. Nylon Nut-Headlamp Door to Radiator Grille / Obsolete / Not listed in Carpenters '67/79 truck catalog / 471 available NOS / Multiple FoMoCo Dealers/obsolete parts vendors have at least 20 each.
378471-S101 .. Screw-Use with 376309-S / #10 -16 x 1.00" / Obsolete / MANDERBACH FORD in Temple PA has 9 = 610-929-3659 / Should be available from any hardware store.
Applications: 1967/72 F100/350.
Old Apr 24, 2012 | 06:21 PM
kenny nunez's Avatar
kenny nunez
68 grill
Racinray, I had my 68 grill reanodized 10 years ago, whether you powder coat or reanodize you must remove all of the riveted brackets , I ground the rivets and replaced them with #10 -32 stainless screws and lock nuts.
Kenny Nunez
Old Apr 24, 2012 | 10:52 PM
racinray's Avatar
racinray
Thanks for the all the info.I have a standard painted grille found a local powdercoating business to do it in chrome for 125 if I strip the paint.I will be starting a new thread to ask some other questions,
440 sixpack
18
Nov 4, 2018 06:36 PM
ckrampota1
Oct 7, 2017 03:43 PM
skidoorulz
15
Oct 17, 2014 06:07 AM
69fordblues
May 5, 2005 12:20 AM
