Is there a switched power soure in back half of Ex??
Old 04-22-2012, 12:11 PM
ToysRUs's Avatar
ToysRUs
ToysRUs is offline
I need to wire my new backup camera to switched power.
I'd prefer to tap an existing source rather than pull a home run from the front.
I cannot use the reverse or running lights as it is plugging into my Insight and I want to be able to switch it on and off whenever I want.
Did a search and didn't find any pertinent answers. Any suggestions?
Old 04-22-2012, 12:37 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
the trailer power wire on the 7 pin plug is keyed.
Thats the only one i can think of.
Old 04-22-2012, 02:05 PM
ToysRUs's Avatar
ToysRUs
ToysRUs is offline
I was just looking at that.
It's just a pia to get to with the sideways bracket and all.
I'm amazed with all that goes on in the back half of the truck that there is nothing.
I have the whole drivers side rear interior apart. You'd think there would be something you could tap into.
Old 04-22-2012, 02:58 PM
swheeler's Avatar
swheeler
swheeler is offline
Remove the rear license plate. Then you can reach in and over to the left. There is a plug in there that connects the harness for the trailer plug. Its a pia but you can unplug it and plug it back in with one hand and some patience. Once you have it unplugged, you can pull the harness out a bit to use a test lit to identify the switched wire. Then simply use a scotch lock to tap into it.
Old 04-22-2012, 03:32 PM
ToysRUs's Avatar
ToysRUs
ToysRUs is offline
Roger that.....
I knew there was a secret access panel!
Thanks.
Old 04-22-2012, 05:40 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
Which backup camera did you decide to use? I can't make up my mind - too many choices & issues......then i loose my patience and put the idea to rest for a while.
Old 04-22-2012, 11:26 PM
pdombrowicki's Avatar
pdombrowicki
pdombrowicki is offline
There is a 12v always on and 12v on with the key that runs to the rear wiper. They run down the driver side quarter panel then up to the middle of the hatch.
Old 04-23-2012, 08:46 AM
ToysRUs's Avatar
ToysRUs
ToysRUs is offline
Thanks, I've already tapped the switched power on the trailer plug.
I will track down and remember the wiper wire!
Old 06-06-2012, 10:45 PM
spinto's Avatar
spinto
spinto is offline
So i tested the power tab, in fact all of them in the 7 pin trailer connector....and nothing....key on....truck running....still nothing!! any thoughts?
River
2009 - 2014 F150
17
12-20-2015 09:33 PM
fordman19762003
Electrical Systems/Wiring
11-13-2012 11:42 AM
Runamuck
09-24-2010 12:50 PM
txaggiegolfer
09-10-2008 04:34 PM
jamlam1
09-21-2003 12:56 PM
Quick Reply: Is there a switched power soure in back half of Ex??
