6.0 no start
Old Apr 20, 2012 | 11:06 PM
simsbud's Avatar
simsbud
6.0 no start
ive posted up on here before a few times and everyone has been very help full , i have a 2005 f-250 4x4 crew cab 200k miles, hpop was changed in 2007 along with 4 injectors, egr cooler, ect, the truck wouldnt start after you run it for a while, so my buddy is a ford tech, we tore the valve covers off and my dummy pipe orings were shot, we replaced the dummy pipes, and he also had some replacement orings for the Stand pipes, now when you turn the key over the oil pressure gauge comes up almost right away but the truck wont fire, before it took about 30 seconds for the gauge to read anything, so i dont know if i am going in the right direction or not, so my issue now is oil pressure gauge reads almost instantly but has no start, where before it wouldnt read until you turned it over for about 30 seconds or so, can anyone give me any input thanks,,, truck isnt throwing any codes
Old Apr 20, 2012 | 11:15 PM
bismic's Avatar
bismic
You may not have cranked enough yet to get all the air out after the work, or you may have trash in the IPR valve. Both are fairly common occurences.
Old Apr 20, 2012 | 11:17 PM
simsbud's Avatar
simsbud
i drove it home from his shop about 10 miles,
Old Apr 20, 2012 | 11:23 PM
bismic's Avatar
bismic
So I would bet on the trash in the IPR.
Get a scan tool that will read ICP, ICP desired, and IPR duty cycle.
Old Apr 20, 2012 | 11:30 PM
simsbud's Avatar
simsbud
my buddy is a diesel tech at our local ford dealer, im bring it to him tomorrow hes going to hook it up to the machine and also check the IPR valve, i didnt even know about the ipr valve thanks for the advice!!!
Old Apr 21, 2012 | 03:03 PM
simsbud's Avatar
simsbud
number 3 injector was bad!!! the oring inside was blown out, put a new one in, he flashed my pcm, ficm and tranny module truck is as good as new, and it only cost me the part!!! thanks everyone for your help,, i really appreciate it!!!!!
Old Apr 21, 2012 | 04:11 PM
BLADE35's Avatar
BLADE35
Thanks for posting the outcome reps given
Kerly
Sep 17, 2016 01:18 AM
Ford79
Jun 17, 2014 06:32 PM
aj197816134
May 22, 2014 10:21 PM
Skattracker3
May 7, 2013 03:59 PM
davinci69
Feb 19, 2013 08:58 PM
