Ecoboost-FFV Engine?
You didn't miss anything my friend, it's gasoline only.
https://www.ford-trucks.com/forums/1...-ecoboost.html
https://www.ford-trucks.com/forums/1...-flexfuel.html
MikeWolfe was trying it, but we've never heard back from him.
Had the newest ECU software updates done by the local dealer last month
Been using a mix of 50% E85 & 50% Premium in my 2011 FORD F150 Super Crew 4X4 for several months now.
No problems noted.
Engine has a lot more power with this mix which I estimate is about 100 Octane.
Mileage was between 19.1 & 20.2 with premium only.
Averaging 17.5 to 18.3 with the 50-50 mix.
Works great for me.
No problems noted.
Works great for me.
The big reason for the switch from MTBE to Ethanol is because, in many places in the country, we're finding high levels of MTBE in the ground water. Since it's a toxic contaminant, that's not exactly a good thing. Whether you're a tree hugging liberal or not.
Ethanol, by comparison, is much safer. I have no problem taking a big swig of Ethanol, but you wouldn't catch me drinking MTBE (unless I had already previously consumed a lot of ethanol and you dared me).
that kind talk is only intended to provoke and enrage people and is not needed.
you don't like it ... fine, whatever.
but your opinion is your own and is not shared by everyone on the forum. there are those of us who think it is a legitimate alternative to feed our vehicles. That hardly makes us gay, tree hugging liberals.
comparing the efficiency of the to fuels is a pretty narrow view, IMO. It is like saying "gas is crap because it does not yield the mileage a of diesel" ... they both have their place.
furthermore, crippling e85 by running it in an engine optimized for 87octane is like runing race gas in an engine with 6.0:1 compression and no timing lead. you can make it run, but there are prices to be paid, and efficiency is one of them. E85 like 12:1 compression at a minimum, or you are bound to get low efficiency.
flex fuels arent going anywhere ... better get used to the idea of them being around.
At the federal level, the government actually doesn't force it. What they did do, is remove the provision that shielded MTBE manufacturers from lawsuits related to cleaning up MTBE ground water contamination. Instead of our tax dollars paying for MTBE cleanup through the EPA, it's now paid for by those private companies.
For many of those companies it didn't make sense to continue producing MTBE, when they could produce Ethanol which has little risk of groundwater contamination and, for a while, carried tax subsidies. Hence the phase out of MTBE in favor of E10.
Now, there are many state governments that do force E10, but that's a state government issue, not a federal issue.
