Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
330 swap????
Old Jun 6, 2012 | 09:02 AM
kelso1's Avatar
kelso1
Ok Numberdummy, What about this N60AU652032 ? From what I have found, this is a 1965 Ford N600 with a 330 M/D 2V. The customer says that it is a 66 and claims that the title says that as well. He wants the 330 replaced with a 390. I informed him that from what I have researched, the crank snout is smaller on the 390 and a custom spacer will be needed to seal the cam cover when the FT engine mount is used. Am I correct?
Old Jun 6, 2012 | 09:28 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The 330MD should have the smaller crank snout. Same as the FE. Only way to really tell? Measure it.
Old Jun 6, 2012 | 10:33 AM
kelso1's Avatar
kelso1
Front crank snout is 1.375" so this should be a direct replacement, right?
Old Jun 6, 2012 | 10:56 AM
krewat's Avatar
krewat
Yeah, I think the two sizes are 1 3/8", and 1 3/4", so 1.375 makes it 1 3/8" or the FE size.
Old Jun 6, 2012 | 10:57 AM
krewat's Avatar
krewat
Ford FE Crankshaft Casting Numbers - FORDification.com
Old Jun 6, 2012 | 12:10 PM
kelso1's Avatar
kelso1
I don't have the ability to remove the pan yet. This is a great link though. As far as the VIN goes....Is it a 65?
Old Feb 14, 2015 | 11:32 AM
Papa Steve's Avatar
Papa Steve
I have a '69 F-600 with a 330, so will big block headers fit this engine?
Old Feb 14, 2015 | 12:14 PM
fellro86's Avatar
fellro86
Not really a "big block" or other, just FE/FT. You would have to find a set of FE headers, which I believe might be the same. I would have to go look at my 330 again and see if the bolt holes look to be located the same as an FE.
Old Feb 14, 2015 | 04:58 PM
85e150's Avatar
85e150
There are some comments here about FT/FE interchange, and some specific comments about the exhaust crossover:
Converting FT Block to FE Setup - Ford F150 Forum - Community of Ford Truck Fans
Old Feb 14, 2015 | 06:57 PM
Papa Steve's Avatar
Papa Steve
This was very helpful. I gained a ton of info from the above site. This forum has the greatest people! Thanks so very much.
Old Jun 4, 2015 | 07:03 PM
Kevin1966f600's Avatar
Kevin1966f600
my 66 vin
Anyone know anything about my Vin it's
SERIAL # F60CK809669
MODEL # F600
BODY # 481
AXLE code G2C
Trans , N
Anything anyone can tell me would be appreciated, the guy I bought it from raved that it has a HD 330 , i had never heard of that motor before this truck, i considered myself a ford enthusiast, i guess not lol
Old Jun 4, 2015 | 07:06 PM
Kevin1966f600
Old Jun 6, 2015 | 06:03 PM
  #28
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Uh huh...
N60 = N600 (gas).
A = 330 2V Medium Duty FT engine.
U = Louisville KY Assembly Plant.
652032 = 1965 .. assembled February 1965.
1964/65's with FT engines used different VIN engine codes than 1966/78.
So, if this was a 1966: C = 330 2V Medium Duty FT engine.
Pic: Scroll down to engine codes.
Old Jun 6, 2015 | 06:26 PM
  #29
krewat's Avatar
krewat
So in other words, the title is wrong
nickerns92
Large Truck
Dec 1, 2019 03:00 PM
willisgiles
Large Truck
23
Dec 26, 2018 04:55 AM
petebert
Large Truck
Dec 14, 2017 04:55 PM
grumpy1
401, 477, & 534 SD Engines
Jan 31, 2006 04:04 AM
turbo98
Oct 17, 2005 12:40 PM
