67 to 72 F600 Engine identification
He everyone! I think I've found the correct thread this time. Looking for some insight on identifying the engine in my rig.
(Quick note, Washington State Title claims it's a 1966 (body is of 67-72 style) and door tag claims 1969)
I bought an F600 flatbed from a nice guy, everything he told me corresponded to the door tag, which claims, 1969, 330engine, Wimbledon White, San Jose, etc. Engine has 5 bolts on the valve and a 352 casting stamp, so I'm thinking it's 352,360,390. Either engine or door is unoriginal.
How do I find out more on the engine, and any tips on finding a chassis Vin?(I checked in the top passenger frame rail for grille to bed mount, aside from under cab) thanks in advance
The 330 FT engine will visually look like the FE series engines to a certain extent. There are some differences like the oil filter setup and the large crank snout on the heavy duty 330. I believe heavy duty 330 did not have a spin on oil filter, it was a cartridge type. Check your intake to make sure there isn't a metal identification tag bolted on. You could pull a spark plug and measure stroke with a wooden dowel but I believe 330 and 352,360 all share 3.5" stroke. Could pull a head and measure bore....330 I believe is 3.875" bore compared to 4.00" on others.
Check this thread out
https://www.ford-trucks.com/forums/1...engine-id.html
Externally, they are nearly identical in any given year, and have the same dimensions.
They share the same bore and stroke in two cases, 360/361 and 390/391.
Internally they are different in that the FT block has a larger hole for the distributor, some are said to have reinforced lower ends. Pistons and cranks are different as well. Blocks may have an oil return port for trucks with air compressors for air brakes.
Heads and intake/exhaust manifolds differ. The FT uses a central exhaust cross over port, the FE offsets the cross over. Carbs and distributors are governed on FT motors. Oil filters are different--cartridge vs spin on in some models. Oil pans differ.
Front covers differ due to the larger crank snout and the provision for the front engine mount. They are iron vs. aluminum for the FE. Bell housings differ, as they have the rear engine mounts incorporated on the sides.
There are more differences but I think that's enough for the moment.
As Bill said it's a 330 MD engine.
MD 330 has FT heads, intake and exhaust manifolds, used a FE style water pump and has the smaller crank snout.
Standard FE style non governed distributor and autolite 2 barrel carb.
Has electric choke so the carb has been changed and the vacuum governor is missing.
These trucks originally came with manual choke carbs, the vacuum governor looks like a 2 inch carb spacer with a set of throttle blades in it.
HD engine had different water pump, timing cover and larger crank snout, they also had governed dist and Holley carbs
so how is a 330 ft engine? Anything good about it, bad about it or special? I have just purchased one in a 65 F-600 and am just wondering about it.
A 1965 anything would be a question mark. If it runs, hits on all cylinders and doesn't leak or burn oil, it will probably last a good long time.
Flame Out
06-28-2010 03:47 PM
XQUZME
1999 to 2016 Super Duty
23
06-19-2009 08:17 PM
