I have a early 99 F250 7.3. What are the functions the Scangauge II will display for my truck? It was my understanding that the scanguage would not show transmission temperature ?
You'll just have to search some older threads and google to see if you can find the codes. Those things don't read much on the 7.3 out of the box. Some have figure out certain codes (look more like equations) that you can enter so it recognizes and starts to monitor other things. I don't know if tranny temp is one of them.
The Aeroforce scangauge will monitor the tranny temps for you. You just need to select it from the menu of things to monitor.
The aeroforce scan guage will scan all sorts of things, as well as run an injector buzz test and cylinder contribution test. The rectangular scangauge II won't pull nearly as much information or pull many meaningful codes, or be able to run any tests.
FICM Main Power: (Volts) (Should be 47-48) (This one isnt working on mine, anyone have different codes?)
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP
Glow Plug Percent: (haven't tried this one yet)
TXD: C410F1221430
RXF: 046205140630
RXD: 3008
MTH: 0F5127100000
NAM: GP%
