haveing surging problems
Old Apr 19, 2012 | 11:51 AM
69dave's Avatar
69dave
hello, i'm kinda new to this, i'm haveing problems with my 99 7.3 surging at about 1500 to 2000 rpm, i have replaced my cps, fuel filter changed oil, wiggled all wires wile running and no change, i pulled two codes one was ,po603 and the other is p1396, the 603 is internal ctrl mod Kam error does any one know what that is? the other is my glow plugs but that shouldn't have anything to do after it starts any info will help thanks
Old Apr 19, 2012 | 12:55 PM
Kdr358's Avatar
Kdr358
I don't know very much about diesels since I've only owned mine a month. I would look in the 7.3 section I'm guessing this thread will be moved there. How many miles are on the truck?
Old Apr 19, 2012 | 12:57 PM
69dave's Avatar
69dave
it has 218000 miles, im new at this dont know how to post in the 7.3 section,
Old Apr 19, 2012 | 01:08 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
What is the truck doing? You are saying surging, but I'm not sure what you mean.
Old Apr 19, 2012 | 01:32 PM
69dave's Avatar
69dave
it is missing at 1500 to 2000 rpm it pulsates the rpm will drop about 200 rpm then right back i had the issue before and it was the tps, i figured that out by putting on cruise control, when i did that it went away but this time it still does it, it has power you put your foot in it and its fine, right now i'm cleaning the EBPS and tube check the ICP there is oil in connector, thanks
Old Apr 19, 2012 | 01:42 PM
redford's Avatar
redford
FTE Leadership Emeritus
69dave, welcome to FTE!
Here is a link to the 7.3L Power Stroke engine forum.
1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
They should be able to solve your engine issue.
Old Apr 19, 2012 | 09:59 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Apr 19, 2012 | 10:24 PM
BigAlsPSD's Avatar
BigAlsPSD
Here is a link to the current thread by the OP https://www.ford-trucks.com/forums/1...-2000-rpm.html
id_birdhntr
Sep 24, 2012 04:03 PM
Big Blue 350
Apr 20, 2011 04:28 PM
Stevemb
Nov 4, 2010 09:00 PM
mrsandog
Apr 9, 2007 12:52 AM
DEESUL
22
Jan 24, 2006 05:06 AM
