Interior Light Kill Switch
Old May 1, 2003 | 09:19 AM
MisterCMK's Avatar
MisterCMK
I have a 2000 EB, and I was wondering if there was a wahy for me to wire a kill switch for the interior lights. The reason I ask is I camp regularly, and the liftgate gets left open. The battery died twice because of that. I found that if I put a keyring in the liftgate latch, the lights go off. I just want a way to kill all interior lights so I don't have to worry about remembering to take the key ring out, and putting it back in.
-CHRIS
Old May 1, 2003 | 11:01 AM
Darth Baiter's Avatar
Darth Baiter
Try this - it worked for me: https://www.ford-trucks.com/forums/s...threadid=99720
Old May 1, 2003 | 05:16 PM
MisterCMK's Avatar
MisterCMK
Thanks for the information. I am a little confused as to which panel comes off. When looking in the truck from the rear, is it the one directly to your left? The one with a little plastic panel that comes out easily? Also, do you have any pictures of what the switch looks like?
-CHRIS
Old May 1, 2003 | 06:19 PM
97expy5_4's Avatar
97expy5_4
Go to Radio Shack and ask for a on/off rocker switch. (you don't need to buy one that lights up) Then the piller on the left hand side (same as airconditioner) I'll try and post a pic tonight for you.
Anyhow, cut the white w/purple strip wire connect and mount the switch and your done. You'll know right away if you've cut the right wire, lights will go out!
Good Luck
Big Mick
Old May 2, 2003 | 11:04 AM
hokiebob's Avatar
hokiebob
Remove the rear pillar-cover, drivers side, that covers the top anchor-point of the third seat seat-belt and the rear, pop-out window actuator. Cut the white wire/purple stripe and wire in a single pole/single throw rocker switch (Radio shack - $3.00). I used a 3/4" wood bit to drill the hole in the panel and it worked absolutely perfect--I placed the hole directly behind the third seat seatbelt so you really cant see it. Good luck.
Old May 5, 2003 | 10:58 AM
golakers's Avatar
golakers
I did this mod over the weekend, took less than 30 min. looks professional... lovin' it
salazar44
Jan 2, 2017 02:48 PM
bbells2009
49
Oct 11, 2016 02:20 PM
Mudrat_Explorer
Oct 22, 2013 06:05 PM
SRobo09
Apr 15, 2011 10:13 PM
Jackyboy
Oct 26, 2004 03:17 PM
