one red rod?
Old Apr 17, 2012 | 08:36 PM
wasowski's Avatar
wasowski
one red rod?
so i pulled the 390 out of the truck and pulled it apart and found one the rods was red and the bottom of the piston also ,read the steve christ book and checked on line and could not find anyone else with this problem.the piston tops all look good with little build up ,going to have a machine shop do the heads ,just want make sure the engine is ok before i put her back end and i have been off work so i do not have extra change to do a full on overhall,
i will post more pic's we i get her back together and ready to put back end
Old Apr 17, 2012 | 09:28 PM
mikeo0o0o0's Avatar
mikeo0o0o0
IIRC this was discussed in another thread and there was no consesus on whether it had any significance or not.
I'd pull the cap on that rod and a couple of others, if they look the same put the caps back on, torque them down and don't worry about it.
Old Apr 17, 2012 | 09:31 PM
impalaslayer's Avatar
impalaslayer
maybe some recall or something from back in the day? i know on the 03/04 cobras the drivers side head had a recall on it and they painted it blue
Old Apr 17, 2012 | 09:35 PM
wasowski's Avatar
wasowski
thanks mike i will keep on keeping on , might be a few weeks out on the machine shop so that gives me time to check that out, clean and through some paint at it ,
now i just need to get the headers on order
Old Apr 18, 2012 | 05:25 AM
FineSeventyNine's Avatar
FineSeventyNine
Tennessee Hillbilly
Years ago if one(or more) cylinder was bored out of tolerance they had slightly oversize piston/ring assemblies to put in place of a stock size. I've seen main bearings pulled from stock engines also that read .0003-.0008 (3 to 8 ten thousandths undersize) to get the correct clearance.
Not saying this is your answer, just that things like that were done to get engines going and installed in vehicles. This could have also been one that was perhaps replaced at a dealer under warranty? who knows?
I fixed a Jeep a few monthes ago that had a skirt on the piston broken off. The factory piston assemblies were coded A-F according to the size, which varied
from about .002 -.005 oversize.
Measure everything closely to be sure.....Good Luck with it!
jonezzzman
29
Aug 16, 2013 01:12 PM
sc00ter
Feb 12, 2009 10:07 PM
Chumbucket
Apr 12, 2006 02:44 PM
rusty70f100
Dec 4, 2005 05:36 AM
97powerstroke
Aug 13, 2004 09:19 PM
