Power Steering Pump Pulley
Old Apr 17, 2012 | 08:28 PM
Evan_P's Avatar
Evan_P
Well the issue came up in my 3G swap thread and didn't really seem like it belonged there. So my power steering pulley has some play in it. Its strait forward and back. I think this is what is causing my belt squeal. Here is the play:
Can I tighten something to fix it or is the pump on its way out? Should I replace it? Saginaw swap maybe?
Power steering pump pulley - YouTube
Old Apr 17, 2012 | 09:55 PM
ichabod40's Avatar
ichabod40
The pulley is pressed onto the end of the pump shaft. So, IMO, all of that play is coming from inside your P/S pump.
Old Apr 17, 2012 | 10:23 PM
Evan_P's Avatar
Evan_P
Yeah thats what I was thinking... Might be time for a saginaw swap... Other than the pump,bracket and possibly a new belt, what else is needed?
minnesotafisherman's Avatar
minnesotafisherman
Does the power steering pump itself move back and forth if you are holding onto the reservoir? Or just the pulley?
Old Apr 17, 2012 | 10:24 PM
ctubutis's Avatar
ctubutis
Yeah, that looks to me like the bearing in the pump.
Old Apr 17, 2012 | 10:25 PM
ichabod40's Avatar
ichabod40
As far as I know you'll only need the pump and pulley, bracket and new pressure hose. It should run the same belt.
Old Apr 17, 2012 | 10:26 PM
Evan_P's Avatar
Evan_P
I will check tomorrow if the reservoir moves too but I think its only the pulley moving.
Old Apr 17, 2012 | 10:27 PM
Evan_P's Avatar
Evan_P
I wouldn't be surprised if the pump was bad. Its been turning 35's for the last 9 years...
Old Apr 18, 2012 | 09:07 PM
Evan_P's Avatar
Evan_P
What kind of new pressure hose do I need? Ive read somewhere it a 70- something F250?
Old Apr 18, 2012 | 09:13 PM
minnesotafisherman
Pretty sure it's the '79 F250 hose you need. Don't quote me on that though.
oxt127
Dec 29, 2015 09:22 PM
giwdul
Dec 16, 2015 11:28 PM
westcoastslider
Oct 25, 2008 11:10 AM
jnj4fords
May 21, 2006 12:14 PM
flyflinger
Oct 16, 2005 08:58 PM
