Fuel pump dieing?
Old Apr 17, 2012 | 07:38 PM
Rossner's Avatar
Rossner
Fuel pump dieing?
I have a 2004 F250 6.0L, 4in lift, 35in tires, Amsoil oil bypass filter+cooler, soon a coolant filter, and i just did a blue spring upgrade. I took it out for a test drive and heres what i got for fuel pressure
Idle-66psi
20%-60psi
30%-54psi
40%-48psi
50%-40psi
WOT-20psi
I changed the fuel filters about 6000 miles ago and im guna change them again tomorrow and see if that works. Any other ideas? Im thinking if that dosent work maybe a fuel pump?
Old Apr 17, 2012 | 09:43 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I'd double check that regulator update install before buying a pump. Maybe blow some air through the lines. Hopefully you're on the right track with the filters though. Good luck!
After thought: I wonder if the fuel pressure test port is before or after the regulator part of the filter housing?
Old Apr 17, 2012 | 11:08 PM
dchamberlain's Avatar
dchamberlain
It wouldn't be much good as a pressure test port if it was not on the pressure regulated side.
Old Apr 17, 2012 | 11:51 PM
Rossner's Avatar
Rossner
Ill do the filter change tomorrow and let you know if that helped.
Old Apr 18, 2012 | 04:44 AM
critterf1's Avatar
critterf1
Faulty pump.
Old Apr 18, 2012 | 08:10 AM
raptor131's Avatar
raptor131
It is after, it is reading the pressure right as it goes to the injectors. In other words it should be the same there as at the injector from what I understand.
The only thing I wonder is how much air in the line can affect the pressure reading. Since a liquid cannot compress but air can. If there is any air in those lines including the one to the pressure sender it will affect the reading. That is why the strictly diesel one is so well engineered it has the shrader valve right where the sender is installed . It allows you to bleed off any trapped air so that the sender is only getting fuel
Old Apr 18, 2012 | 09:02 AM
69cj's Avatar
69cj
Are you using OEM filters?
Old Apr 18, 2012 | 07:31 PM
bismic's Avatar
bismic
For stock engines, there can be up to a 10 psi pressure drop in the fuel rails.
Old Apr 18, 2012 | 10:00 PM
Rossner's Avatar
Rossner
So i changes the filters, and there is no change in the fuel pressure and yes i use the OEM filters
keiseldiesel
Apr 13, 2015 09:33 AM
jglass9999
17
Apr 23, 2013 10:27 AM
trqjnky
Modular V10 (6.8l)
Sep 4, 2012 03:24 PM
rev_man
Modular V10 (6.8l)
17
Dec 19, 2010 09:54 PM
paddler
Apr 25, 2003 09:03 AM
