30 psi? fuel pump?
Old Apr 9, 2015 | 07:02 PM
keiseldiesel's Avatar
keiseldiesel
30 psi? fuel pump?
i checked my fuel pressure today and it was only at 27-30 psi at idle. i then took it for a test drive while looking at the gauge. at WOT i was getting maybe 10 psi. So my first thought was the tank filters might be gunked up. I went further and disconnected the line from the tank to the fuel pump. And ran a fuel line from the pump to a 5 gal can. started the truck and the same result happened. Is there any way i can make for sure its the fuel pump? or is there something else on the fuel bowl that i should check first. thanks yall!
e99 f250, 4in, 6637, gauges.
Old Apr 9, 2015 | 07:04 PM
whitetmw's Avatar
whitetmw
Check the discharge side of the pump.
Old Apr 9, 2015 | 07:12 PM
excavator's Avatar
excavator
when my e99 acted like this it was the fuel pressure regulator bad. I repaired with this kit Rebuild Kit for the 1999-2003 Fuel Bowl Pressure Relief Valve
Here is the billet style upgrade http://www.dieselorings.com/1999-200...m-springs.html
Old Apr 10, 2015 | 12:11 AM
Tugly's Avatar
Tugly
Open pressure side, blow air back, and look for chunks. Hook the pressure side back up, use your bucket to supply the pump, open the fuel bowl drain into a container, and measure the flow. This will completely bypass any clogging or regulator questions.
When was your last fuel filter change? Any fuel mods?
Old Apr 10, 2015 | 12:48 PM
keiseldiesel
I changed the filter last month. And no fuel mods
Old Apr 13, 2015 | 09:33 AM
F250_'s Avatar
F250_
When the plastic pickup foot in the tank starts crumbling and falling apart, or if you get trash-contaminated fuel, it can create pluggage in the top bend of the suction tubing right on top of the tank, and the fuel flow can go to "almost no flow" conditions quite easily.
732t37
Nov 7, 2010 05:55 PM
rjlucas
Dec 24, 2007 10:23 PM
DJdemon6696
27
Dec 2, 2007 04:43 PM
switzee
Bronco II
Aug 23, 2005 04:11 PM
Tex311
Bronco II
Jan 23, 2004 10:50 PM
