Help installing new tailgate handle
Old Apr 16, 2012 | 10:21 PM
money pit 69's Avatar
money pit 69
Just received my new chrome tailgate handle and plate from LMC. Trying to install I got the rods hooked up but there is no spring action. The handle just moves freely up and down. Rods are hooked to the latches just fine. Where did I go wrong? Help would be appreciated. THX David
Old Apr 17, 2012 | 03:47 PM
MIKES 68 F100's Avatar
MIKES 68 F100
up ? my 68 is a side lever , tension springs are in tailgate at latches
Old Apr 17, 2012 | 07:21 PM
tmcalavy's Avatar
tmcalavy
Yeah, my 69 latch is a side-pull too...left edge pulls out. I think the up latches came out in 71 or 72, but may be wrong.
Old Apr 17, 2012 | 09:40 PM
orich's Avatar
orich
The two end latches are spring loaded. The 1973 and up the opening latch lifts up to open. The 1964-72 have a pivot bolt for the opening handle that bolt on to with rods that pull the latch release that is spring loaded. No other spring shown..orich
Old Apr 19, 2012 | 08:00 AM
68Ford4Life's Avatar
68Ford4Life
if your lever moves up and down, you may have the wrong one bud.
Old Apr 19, 2012 | 08:33 AM
orich's Avatar
orich
If it's moving up & down you've got the wrong tailgate Handle better post a picture of it ..is all I can say..
Old Apr 21, 2012 | 08:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4TZ-99431B82-A .. Styleside Tailgate Handle (does not include the mounting plate).
C4TZ-99431D78-A .. Styleside Tailgate Handle Mounting Plate.
C4TZ-99431D76-A .. Styleside Tailgate Latch-includes Spring / Right/Left is the same.
Applications: 1964/66 F100/250 2WD * / 1966 F100 4WD * / 1967/72 F100/350.
Did'ja know (prolly not): September 1966, Ford obsoleted the 1964/66 Styleside tailgate (C4TZ-9940700-A *), replaced it with the 1967 (1967/72) Styleside tailgate (C7TZ-9940700-A) for use as a service part replacement.
ALL the mounting hardware is the same! The only difference is that the 1967/72 tailgate's FORD letters are a slightly different shape and are surrounded by a raised ovate scallop line.
btw: The tailgate supports aka scissors aka straps (C4TZ-9944400-A) are the same thru 1979 as are their rubber bumpers (C4TZ-9944482-B).
* 1964/65 F100/250 4WD, 1964/66 F350, 1966 F250 4WD used the 1957/60 Styleside Beds, so the tailgate is not the same as C4TZ/C7TZ-9940700-A.
Old Apr 24, 2012 | 11:34 AM
money pit 69
THX to all responces, i guess my post did not explain my problem clear. The plate and handle are the right ones. The problem is when the rods are hooked up there is no spring tenison on the handle. I think I need to depress the latches then hook up the rods. Or maybe I have the rods hooked to the wrong hole. THX David
kpchambers
2009 - 2014 F150
Jan 12, 2017 06:37 AM
Tahnka
Oct 8, 2010 03:59 PM
fatbat
Apr 7, 2007 09:16 PM
airrikk17
1978 - 1996 Big Bronco
Oct 7, 2004 08:24 PM
