information needed
Old Apr 16, 2012 | 04:18 PM
lugnut68's Avatar
lugnut68
information needed
Hello all. Just found your site and I am very happy for it.
I recently (2 days ago) bought my dream truck. A well worn F-250 Camper Special with a 460 and a 4 speed.
I live in the CaliforniaSSR and have just found out the 2bbl carb my truck came with is not legal (go figure). I'm trying to find out what came stock on my truck and how to find one to replace the 500cfm holley its currently running.
Any part numbers, good guesses, crayon drawings or links to other sites would be much appreciated. My goal is to make it legal and smoggable.
Thank you for looking.
lugnut68
Old Apr 16, 2012 | 04:32 PM
mikeo0o0o0's Avatar
mikeo0o0o0
First, was the truck originally equipped with California emissions?
What's the DSO (Last code on the door warranty plate)?
If this is for the '78 in your profile, according to the Ford parts catalog it should have a Motorcraft 4 bbl carb.
Motorcraft carbs have a metal tag that identifies them held on by one of the bowl screws.
This is what the Ford parts catalog says:
Carburetor
78 F150-250 w Cal emissions
Tag number D8TE-AKA
P/N D8TZ-9510-AK
BTW, welcome to FTE, lots of good, knowledgeable people here.
Old Apr 16, 2012 | 04:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
By having the tag number, you should be able to find a rebuilt. Just incase you can't I did a parts search and found two new ones.
Carburetor D8TZ-9510-AK
Parts International, Farmers Branch, TX has 1 (972) 241-8730
Kinsel Lincoln-Mercury, Beaumont, TX has 1 (800) 816-2894
Old Apr 16, 2012 | 05:15 PM
lugnut68's Avatar
lugnut68
DSO code
Wow, thanks for the reply.
My DSO code is 72
My Vin is F26SRCC5606.
Don't know if the vin is useful
I called the parts house and that carb you turned me on to is 534.00 dollars. (Wife is going top do cheetah flips when she hears this, but---meh. She'll get over it.
So if my DSO and vin concur and say that's the carb for me, I'll buy asap.
Btw, will have to use a stock cast-iron manifold or will a performer suffice?
Thanks again.
Old Apr 16, 2012 | 06:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
My DSO code is 72
Thanks again.
If it has a 460 in it, someone swapped it in. It originally had a 400 from the factory. If it was a factory 460 the fourth character of the VIN would be "J".
F26SRCC5606
F26=F250 4WD pick up
S= 400 cu in 2 bbl carb
R= San Jose Assembly plant
CC5606= Consecutive serial number.
DSO 72= San Jose District Sales Office
Double check and see if it's a 400 instead of a 460.
And I'd say it did come with Cali emissions.
Old Apr 16, 2012 | 06:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
One way to tell the difference is count the valve cover bolts. IIRC a 460 will have 7 bolts on each cover. The 400 will have 8. If I'm wrong someone will be along to correct me.
78 & 87 Super Cab
Jun 10, 2015 01:30 PM
raygant
Sep 25, 2012 08:03 PM
BlackLabel78
Mar 3, 2010 03:31 PM
76 F-150 390FE
May 27, 2008 01:20 PM
cvellanti
Aug 5, 2004 09:44 PM
