Gas Tank Question
Old Apr 17, 2012 | 12:22 PM
batchman's Avatar
batchman
Originally Posted by 85lebaront2
I would still ground the tank, I don't know on the mechanical fuel pump applications, but on the 351 and 460 with the hot fuel handling package there are 4 wires due to the in-tank low pressure pumps. I have run into a number of replacement pump units where the gauge sender ground was a dummy. Ford used the same style pin on all four terminals, just the sender ground had a metal ring on the inside. The Chinese built replacements, and even a NAPA one have insulating rings on all four, and no ground for the sender as a result.
If you ground the sender wire(s) the gauge should go all the way to full on an 86. If it doesn't, the you have a gauge problem. On these trucks, open circuit will read empty.
I would not recommend grounding the tank. If something hot inside were to touch a grounded tank it could draw a spark. If the tank is not full that would mean vapors are present.
If the tank is not grounded then it would not complete a circuit.
JMHO,
- Jeff
Old Apr 17, 2012 | 12:37 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Jeff, the original fuel pump modules were grounded by the black wire to the chassis grounds, if you have replaced these with aftermarket ones you have to ground the tank or the gauge will not work, up through 88 they read empty with no ground, 89 up they read full with no ground.
Old Apr 17, 2012 | 01:47 PM
fellro86's Avatar
fellro86
Gas tanks have been grounded for a very long time. If you don't, you risk static charge buildup. Also, by the philosophy of a short being the risk, the pumps in the tank have their own ground, so the risk is still there. The sender itself does not run full 12v, and is low amperage.
Old Apr 17, 2012 | 02:20 PM
nolan62's Avatar
nolan62
Are you sure the sender does NOT run at 12v? I noticed that there wasn't 12v on that connector. Do you know what the correct voltage is?
Old Apr 17, 2012 | 02:31 PM
82f100460's Avatar
82f100460
All of your instruments (fuel, coolant and oil) run off the intrument voltage regualtor that provides 5V to the senders....optimum. may be little off from there but should be by much.
Old Apr 17, 2012 | 02:39 PM
klricks's Avatar
klricks
The voltage is 5V which pulses on and off at a rate of about half a second.
A digital volt meter will show erratic reading. If your meter has a bar display then that works or use an analog meter. A test light would work as well but be somewhat dim.
Old Apr 17, 2012 | 02:41 PM
nolan62's Avatar
nolan62
Yeah, I thought the gauges ran off 5v but the sender ran off 12v. Now that I think about it I'm not sure why I thought that.
Old Apr 17, 2012 | 02:54 PM
82f100460's Avatar
82f100460
yes sir...all in the same
Old Apr 17, 2012 | 02:55 PM
ctubutis's Avatar
ctubutis
That's an unreadable picture, Kev....
Old Apr 17, 2012 | 02:58 PM
82f100460's Avatar
82f100460
yeah that's terrible isn't it?? Let me try again
nolan62's Avatar
nolan62
There at the top, which Resistance wire is that?
Old Apr 17, 2012 | 03:05 PM
82f100460's Avatar
82f100460
try again....
8-9 ohms on the resistor
Old Apr 17, 2012 | 03:12 PM
  #28
ctubutis's Avatar
ctubutis
Here's one for ya, too:
Old Apr 17, 2012 | 03:15 PM
  #29
82f100460's Avatar
82f100460
show off
armyaviation
Feb 2, 2017 06:31 PM
Brother Hec
Apr 11, 2016 01:12 PM
alvin
May 22, 2009 09:36 PM
zsir
13
Nov 9, 2003 09:12 AM
Gwilkrrs
Mar 4, 2003 07:51 PM
