Have 88' Bronco II. No emergency brakes. Went to wrecking yard and got the "bars" for the emergency brakes. Didn't have any. Question, is there a special tool for pulling the brake cable. Have loosened the adjustment nuts on the adjuster under the truck but can't pull enough slack outta the cable going into the brake assembly to connect to the brake shoe. Thanks!!!
