Sponsored by: Real Truck
Speedometer Issues
Old Apr 15, 2012 | 11:56 AM
95FordTruck02's Avatar
95FordTruck02
Speedometer Issues
My speedometer has been not working for the better part of a week now. Here's the situation:
At start up the speedometer doesn't work. Sometimes it never comes on, sometimes it will engage while driving and the doors lock when it kicks in. If it does start working it is only for a little while and will usually stop again.
I took it by the auto parts and their computer wasn't showing any codes. The overdrive light is blinking.
As a guess, I replaced the speed sensor on top of the differential with no luck. same issue. The fuse isn't blown.
I am running Superlift's Tru Speed, and I don't know if these things go bad or what. The fuse on it is still good, but I haven't disconnected it yet to see if that's the culprit... I wanted to check here for any other ideas because that thing is kinda a pain to get to and disconnect.
Thanks
Old Apr 15, 2012 | 12:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You need to get the codes read. As you found out the auto parts stores can't read Ford transmission codes.
Old Apr 15, 2012 | 01:06 PM
PA-Mark's Avatar
PA-Mark
Damn Mark! 6666 posts, dont see that everyday
Old Jul 6, 2012 | 03:02 PM
95FordTruck02
Just as a follow up in case someone searches for a similar issue-
Turns out my Superlift Truspeed calibrator has in fact bit the dust. I removed it, soldered the original wires back together and I'm back in working order (although with a slightly off speedo).
powerstanderson
Dec 20, 2020 06:27 PM
blueoval65
May 3, 2020 02:03 PM
tkloppel
Jun 10, 2006 08:46 PM
rgiven
Sep 26, 2004 10:59 AM
frodriguez57
Mar 31, 2004 08:07 PM
