Speedometer/Odometer problem
Old Mar 31, 2004 | 06:29 PM
frodriguez57's Avatar
frodriguez57
A few days ago I noticed my speedometer and odometer were not working on my 95 f150. Also noticed my interior dome wasn't working. However, it was still running fine. When I got home I checked the fuses and found number 8 fuse (15 a) out. I replaced. However, the next day when I tried reversing out of the garage my truck stalled. I tried again and again it stalled. I tried going forward in 1st gear (manual tranny) and yes it stalled. I looked on the internet for similar problems and someone mentioned pulling the speedometer fuse. I did that and it runs fine again, but with no speedometer or odometer. Does anyone know what would cause this?
Old Mar 31, 2004 | 06:47 PM
brown 4x4's Avatar
brown 4x4
It could be the speedometer causing the problem. A bouncing needle is unually another symptom. The ones I've seen go bad make it real hard to start moving with a manual tranny, but once you're past that dead spot at about 1 mph you're fine until you slow down again to that same spot, then it'll die.
Old Mar 31, 2004 | 06:58 PM
frodriguez57
You might be right. I drove it awhile without the fuse. I then reinserted the fuse. It was rough at first but I was able to take off. I drove around the neighborhood and did notice the needle trembling. Thanks.
Old Mar 31, 2004 | 08:07 PM
MustangGT221's Avatar
MustangGT221
Does the needle bounce if u get over 60mph? So it has a dead spot at like 2-3 mph? Do a search for Bad PSOM, its a fairly common problem. Sounds like you need a new speedometer module. Typically I suggest checking the rear end sensor and wiring as well as the toothed ring inside the rear end but that is fine if the needle is not bouncing. The dead spot at 2-3 mph is a large hint at it being the speedometer.
Mossyhorns
Aug 21, 2012 04:07 PM
flrp
May 25, 2009 09:38 PM
hansosc
May 31, 2008 02:24 AM
elvis on cape
Aug 15, 2005 07:06 PM
ekender
1978 - 1996 Big Bronco
Oct 20, 2003 10:22 AM
