Replacement engine - difference between 5-speed & E8OD
Old Apr 15, 2012 | 07:55 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Rather than just swapping my head, I'm considering a full engine swap for my 5-speed '91 F-150. Cruising Car-part.com I see separate listings for the 5-speed vs. Automatic versions of the engine. Since the automatic versions seem to be more common, I'm wondering if I can use one of those - yes, no, maybe? What is actually different between the two motors?
Appreciate any insight...
Old Apr 15, 2012 | 08:52 AM
AbandonedBronco's Avatar
AbandonedBronco
About the only difference I can think of would be the flywheel/flexplate on the back of the engine. But, since you already have one, you could reuse what's on the back of yours.
Other than that, I can't think of a single thing that would differentiate them.
Old Apr 16, 2012 | 12:07 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
x2 on the above, the engine itself is the same, only the flexplate/flywheel would be the difference.
Jim
Old Apr 16, 2012 | 12:15 PM
882tank's Avatar
882tank
Absolutely no difference. Go for which ever one is listed cheaper.
Old Apr 16, 2012 | 09:03 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Thanks for the input guys. That makes life a bit easier should I go this route.
Boss9F100
EcoBoost (all engine sizes)
Sep 30, 2020 05:25 PM
Cornettpd
Sep 13, 2018 12:41 PM
puppypower
Modular V8 (4.6L, 5.4L)
May 23, 2006 04:55 PM
mgundry
26
Mar 16, 2004 12:23 AM
chadburns2
Feb 17, 2003 10:17 AM
