Old 11-12-2014, 12:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Replacing brake booster
Old 04-14-2012, 09:47 PM
Ed Bamba's Avatar
Ed Bamba
Ed Bamba is offline
Question Replacing brake booster
Just wondering if there is supposed to be a gasket/seal between the booster and the firewall. When I pulled off the old one, there wasn't one there. There was some rust from the old booster, which I scraped off.
Also, on the brake light switch, there are two spacers and a bushing. Is the second spacer supposed to go outboard between the switch and the spring clip? I think it does, but can't remember.
Old 04-15-2012, 12:19 PM
burnout400m's Avatar
burnout400m
burnout400m is offline
There wasn't a gasket on mine either. I can't remember about the plastic spacers.
Old 04-15-2012, 01:21 PM
Ed Bamba's Avatar
Ed Bamba
Ed Bamba is offline
Thanks Burnout, I was thinking that there isn't supposed to be one. After looking at the shop manual, I'm going to assume that the spacer should be between the cotter pin and the brake light switch bracket.
Old 04-15-2012, 01:25 PM
burnout400m
that sounds right. If I was looking at it I know I could put it back together right but I'm drawing a blank without looking at it.
I can tell you doing it on an F-series is about 20 times easier than trying to get at in in a '74 ranchero.
Old 04-15-2012, 01:45 PM
Ed Bamba's Avatar
Ed Bamba
Ed Bamba is offline
The sad thing is, I only had it off long enough to replace the booster and forgot how it went back together. Sucks getting old
Old 04-15-2012, 02:41 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Ain't that the darn truth!!!!!!!!!
Old 04-15-2012, 04:52 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
On my 89 F250, there was whats left of a gasket bewteen firewall and booster. Not sure if it was factory or a PO put it in. I made a new gasket up to help keep water from coming in.
MartyTheOneManParty
05-14-2016 10:40 PM
psquare7575
11-27-2007 09:36 PM
78bronco
10-09-2002 05:52 PM
Matt67
12-01-2001 03:01 PM
Quick Reply: Replacing brake booster
