Brake Light Switch stopper?
Old Nov 26, 2007 | 09:06 PM
psquare7575's Avatar
psquare7575
Stuck my head under the dash to hook my column up. Noticed this.
http://i9.photobucket.com/albums/a72...k/100_1970.jpg
Is a bolt with a nut really the FoMoCo way of making the brake lights stay off?
Old Nov 26, 2007 | 09:56 PM
73f100shortbed's Avatar
73f100shortbed
I have no idea, but that's a good idea. I zip tied a piece of rubber hose under there to get my brake lights to shut off. Someone has a switch in there with a few seemingly extra wires. I'm afraid to touch it.
Old Nov 26, 2007 | 10:15 PM
whalerron's Avatar
whalerron
That is an interesting way to fix a symptom. The real cause is probably due to your brake pedal not returning completely. On some trucks, there is some linkage between the firewall and the brake booster and that linkage gets rusty. If you take it all apart, clean it up and oil it, the brake light problem will go away.
Old Nov 26, 2007 | 10:38 PM
Mil1ion's Avatar
Mil1ion
No, that is someone elses idea.
They probably installed the wrong pedal assembly or booster so the pedal won't travel enough
What year truck is this on ?
Old Nov 26, 2007 | 11:49 PM
psquare7575
79 F100. As far as I can see, it's a pre DJ-00001 truck
http://i9.photobucket.com/albums/a72...k/100_1635.jpg
The truck has the linkage setup for the booster, and the correct booster. If you've been following my other thread, I added an F350 booster/master combo.
As for the pedal height, I never really noticed it too high or low, but, I'd like to fix it if it's an easy fix.
Old Nov 27, 2007 | 12:06 PM
Mil1ion's Avatar
Mil1ion
I noticed on my Post DJ0001 pedal assembly that there are two holes for brake pedal mounting.
Does that pedal hangar assembly have another hole in it as well ?
That switch has threaded sleeve so it is adjustable.
have you tried sliding it further through the hole ?
Old Nov 27, 2007 | 12:50 PM
psquare7575
Dennis, The pre DJ-0001 hanger doesn't have an extra hole like that, I just checked.
I also removed that bolt/nut assembly, pulled the switch as far as I could through the hole. At the very end of the travel, it just barely makes it. See pic.
http://i9.photobucket.com/albums/a72/psquare75/Truck/100_1974.jpg
I also saw this on my brake pedal
http://i9.photobucket.com/albums/a72/psquare75/Truck/100_1975.jpg
Stamped in large friendly letters are MAN BRK
Manual brake pedal/non power brake pedal perhaps?
I can't take credit for this issue. The truck was like this when my father bought it back in 1999. I figure since I'm doing all this work, I may as well fix any other negative issues.
Old Nov 27, 2007 | 01:13 PM
Mil1ion's Avatar
Mil1ion
Yes you need the Pwr brake pedal.
you need the pedal stamped - MA.
Old Nov 27, 2007 | 01:42 PM
psquare7575
Dennis, there are several F150/F250s near my house in the local salvage yard.
Can I apply this logic
"Any F100/F350, pre DJ0001 with an automatic transmission will have the proper pedal I need"?
Old Nov 27, 2007 | 01:58 PM
Mil1ion's Avatar
Mil1ion
Nope.. 1977/78/ and (pre DJ0001) 79's
Where your's is stamped CA will be an MA
Old Nov 27, 2007 | 03:25 PM
psquare7575
Hmmm.. the hunt begins. 77 to pre DJ0001 79
Old Nov 27, 2007 | 08:58 PM
ford141's Avatar
ford141
Makes sense, my old '79 F100 came with manual brakes, and I remember that with the stock setup the brake pedal sat ~ 2-3 inches closer to the driver than the gas pedal did. After converting everything to power brakes (including matching pedal), the brake and gas were at same level. I wonder if non-power brakes were standard on the 2wd F100's? Mine was a Ranger also. Dennis, maybe you know?
Old Nov 27, 2007 | 09:36 PM
Mil1ion's Avatar
Mil1ion
40 % of 1979 F100's had Power disc brakes.
60 % of 1979 F100's had Manual brakes.
In 1977 and newer ...the brake pedal seems to rest closer to the floor.
psquare7575
Ford Truck Parts for Sale
May 6, 2015 08:06 AM
psquare7575
79
Jul 20, 2013 12:01 AM
psquare7575
110
Apr 24, 2010 03:26 PM
psquare7575
20
Jul 10, 2008 09:15 PM
psquare7575
28
Aug 31, 2007 02:16 PM
