wait to start light
Old Apr 14, 2012 | 08:37 PM
olgold's Avatar
olgold
wait to start light
Haven't posted in a long time...my '89 F250 7.3, 5 speed just keeps on giving ''not much trouble''...been a long time since I needed some expert advice...But, went out today to start the truck and the wait to start light never came on...of course it would not start...was wondering where I should start..glow plugs are all Beru from a couple of years ago...new controller a few years back also..new relay since I've owned it.....just hit 200,000 miles...owned it since 140,000...any advice much appreciated...seems strange the light is gone completely...anyway...thanks for any help....olgold....
Old Apr 14, 2012 | 08:52 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Check the grounds to it.
Old Apr 15, 2012 | 12:41 AM
joshofalltrades's Avatar
joshofalltrades
for a test, try connecting a small jumper wire from the hot large terminal of the controller to the control terminal for about 10 seconds, watching for the light and then cranking at the end of that time. if that does the trick, it would appear that you aren't getting a signal to that wire, and need to check the ignition switch and the wiring. if that doesn't do it, you would appear to have a bad controller or bad grounds.
Old Apr 15, 2012 | 11:36 AM
olgold's Avatar
olgold
wait to start light
thanks for the info...after reading your post it makes sense it might be the ignition switch...have been meaning to replace it for six months...it's getting real sloppy...seems like it won't turn far enough sometimes and then it does....thanks again...will try your suggestion...
Hank85713
Jan 27, 2016 04:26 PM
paddy622
General Diesel Discussion
Jan 15, 2011 05:47 AM
Boo_Daddy
Dec 30, 2007 10:19 PM
1995sho
Sep 10, 2007 03:16 PM
garybanjoman
Dec 30, 2003 07:54 PM
